Direct short in output speakers???
Old Apr 12, 2004 | 07:40 PM
mrm1682's Avatar
Default Direct short in output speakers???
there's a status LED on amp that blinks when i turn on the headunit. the owner's manual says that there's a "direct short in output speaker"....what does this mean??? it's a PG octane-r 2.5:2 amp. also....refer to my post about my install because i'm having another problem with this amp!! https://honda-tech.com/zerothread?id=829741
please help!!!
Old Apr 13, 2004 | 12:46 AM
vteg's Avatar
New User
Default Re: Direct short in output speakers??? (mrm1682)
It means the amp is seeing to much current drawn. If the voice coil has shorted in a speaker you can check it with a multimeter. Check both. If only one has shorted it will have a very low resistance. Probably below 2 ohms.
You can also try disconnecting speakers one at a time to isolate the bad speaker.
Old Apr 13, 2004 | 11:08 PM
mrm1682's Avatar
Default Re: Direct short in output speakers??? (vteg)
problem solved...refer to my other post. thanks for the suggestion though!
headrec*
Audio / Security / Video
Nov 17, 2010 05:17 PM
neli_nael
May 7, 2007 09:41 AM
MilanoCivic97
May 1, 2007 12:17 PM
IloveNewt
10
Mar 21, 2003 10:23 AM
dFreezy
Jan 13, 2003 02:13 PM
