4.73 final drive and boost ???
Is this a realistic setup? 4.73 and boost anywhere from 4psi to 12 psi? I'm using a D series motor. I wanna do this on a 4dr 88-91 civic with lsd and use this as a street/drag setup. Is this too radical a final drive for boost? I searched the final drive and boost but all I found was hydraulic tranny tegs or swapped civics with b series and hydraulic trannys. Didn't yeild definitive results. Anyone here doin this setup? thx
will be pretty crazy, lots of tire smoking action, but it might be nice with a set of 25 or 26" slicks. what kind of power do you plan on making?
I wanna shoot for 200-225? I'm thinkin of a t3 with .42 .48 or a rhb5, I wanna test both. I have a 4.25 final drive l3 Si tranny but since I'm doin the lsd I thought I'd do a 4.73 final drive.
Seems like the gsrs have success with these. people still boost em.
What about on street tires? Or am I crazy?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HARTENG »</TD></TR><TR><TD CLASS="quote">we run a 478 final drive in our car 11.1 at 127 in a lsvtec turbo stock motor</TD></TR></TABLE>
what size slicks did u use?
ls vtec turbo w/ sparks turbo kit 24.5x8x13 mt slicks and ctr trans note the car was going into 5th for a good second oh yeah the car wiegh in at a hefty 2420lbs stock trim street car full glass nothing cut plus a roll cage the car is capable for high tens but the car would not hook for **** at cmi....
p.s got the in car video to post still but here is the car at the street rtaces in the socal valley herehttp://teamstealthonline.com/vids.html
scoll down to turbo gsr they didnt know it was a ls v vs a blown mustang gt not a cobra,note the cobra was a low low 11 car this is at a street not thack so we didnt hook as hard as we should of just watch its cool vid also note we are not alfiliated with team stealth in any way shape or form they just got us on video
Modified by HARTENG at 3:05 PM 4/13/2004
8000rpm the motor will go higher in shift points but remember it is STOCK NO SPRING RET COMBO NO PISTONS,RODS,CAMS, S T O C K BLOCK GUARD AND HEAD STUDS THATS IT WHAT YOU SEE IS WHAT YOU GET TYPE OF DEAL
