91 integra / b16a need some info..
Old Apr 12, 2004 | 03:10 PM
swaplighter's Avatar
Default 91 integra / b16a need some info..
doing a swap for a friend..got a front clip from a jdm teg 90-91? not sure (anybody need any rhd stuff ive got it...really cool digital climate control system..)
need to know of anything i might run into, the small stuff like different wiring or anything. ive done a swap into a std 91 hatch b16a and that was a little tricky. from what i see it should be striaght forward.
thanks for any tips.
Old Apr 12, 2004 | 06:50 PM
DC 2's Avatar
Default Re: 91 integra / b16a need some info.. (swaplighter)
I dont know too much about that swap, Im pretty sure you can retain your stock mounts, You might need the brackets off the b16, but wiring wise just add your 4 extra wires to the pr3: knock,vtec oil p, vtec spool, 2nd o2 . The green plug on the B16 is ur primary which I believe is c16
Old Apr 14, 2004 | 12:46 PM
Default Re: 91 integra / b16a need some info.. (EH3B18B)
hey thanks...also doing a obd1 b18c1 into a 98 hatch.
tony1978
May 1, 2009 06:08 PM
killrB
Nov 24, 2007 03:04 PM
roger22EF
Mar 2, 2005 08:56 AM
paybac4223
Jan 18, 2004 04:15 PM
civichopeful
Aug 2, 2002 01:53 AM
