JDM b16a sir2 turbo question
Old Apr 12, 2004 | 09:22 AM
hair_rice's Avatar
Default JDM b16a sir2 turbo question
alright i need some advice on turboing my JDM b16a sir2...i know the jdm motors have a little higher cr than the usdm, and i was thinkin about slappin a greddy si kit on the jdm motor and run the stock boost...basically i want a lil more power for my daily driver. the question is, is this a good idea to run a greddy kit on a JDM motor? i most likely will get the emanage in the kit so it can be tuned and what not, so is this a good or bad idea? thoughts? advice? all help is wanted thanks!
so here is what i have done to the motor thus far:
its a 99 ex B16a sir2
pnp head, 3 angle valve job, portlow springs and retainers
gsr cams
skunk2 cam gears
FPR
port matched intake mani and tb
also i am runnin the usdm Si ecu i believe its the p2p correct me if i am wrong i always forget.
Old Apr 12, 2004 | 09:26 AM
b16ahybrid's Avatar
Default Re: JDM b16a sir2 turbo question (hair_rice)
Not sure what your looking for.
It's a good idea if your looking for more power.
It's a bad idea if your looking for a gas saver and want 35mpg (you'll be boosting a lot ).
Usdm/Jdm same thing. Usdm 10.2:1 and jdm 10.4:1 cpr.
Old Apr 12, 2004 | 09:45 AM
hair_rice's Avatar
Default Re: JDM b16a sir2 turbo question (b16ahybrid)
yeh im not to concerned with gas mileage...but just wanting to add a lil extra somethin and i have always loved my turbo cars.
i was just curious to the compatibility of the greddy kit and a JDM motor
Old Apr 12, 2004 | 02:29 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hair_rice &raquo;</TD></TR><TR><TD CLASS="quote">
i was just curious to the compatibility of the greddy kit and a JDM motor</TD></TR></TABLE>
Same as a usdm motor.
Old Apr 12, 2004 | 02:40 PM
hair_rice's Avatar
cool thanks
hair_rice's Avatar
what r ur thoughts on the head gasket that can be used to drop the cr
Old Apr 12, 2004 | 03:19 PM
USDMMARK's Avatar
ive been thinking the same thing, with the cr up there, would you have to run a thicker head gasket to lower the cr to boost safely, or is the kit designed to work with this cr, i know someone is going to say tune tune tune, but i don't really know anything about the kit straight out of the box
mark
Old Apr 12, 2004 | 08:10 PM
b16ahybrid's Avatar
Default Re: JDM b16a sir2 turbo question (ORIGIN[AL])
Some like them others like me do fine without them.
I'm runing 9-10psi rite now, hopefully tomorrow i'll be running 12psi stock block.
hondaon18's
Sep 15, 2007 06:29 PM
SuicideSlide
Sep 12, 2006 01:16 PM
ef9robert
May 4, 2006 07:49 AM
B16CRXT
Oct 1, 2003 07:53 PM
1tyme
Dec 7, 2002 06:40 PM
