front camber kit
Old Apr 12, 2004 | 07:08 AM
splinter51's Avatar
Default front camber kit
which one is the best? seen many types of kits not sure which ones are good pieces and which ones are junk. what one do you use.
Old Apr 12, 2004 | 07:16 AM
spaceman's Avatar
Default Re: front camber kit (splinter51)
you could use the search on this website...
Old Apr 12, 2004 | 08:56 AM
red_honda_racer's Avatar
Whatever you do don't get the adjustable upper ball joint ones, I had a friend who had a set and when driving at 40+ the SOB popped out and the whole driver side came crashing down. Go with the the ones that replace your stock anchor bolts, there more adjustable, but you might have to do some grinding to the inner fender lip to get the upper ball joint to tuck up underneath, that is if your slamming it more then 2 inches.
Old Apr 12, 2004 | 09:55 AM
cursED's Avatar
Default Re: front camber kit (red_honda_racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_honda_racer &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you do don't get the adjustable upper ball joint ones, I had a friend who had a set and when driving at 40+ the SOB popped out and the whole driver side came crashing down.</TD></TR></TABLE>
Which brand / what car?
Old Apr 12, 2004 | 10:18 AM
PAB18Si's Avatar
I am getting ready to install some balljoint type camber adjusters, but haven't heard anything bad about them before this, has anyone else experienced this problem of them popping out? thanks
Old Apr 12, 2004 | 11:49 AM
spaceman's Avatar
Default Re: (PAB18Si)
what brand did you get?..i think you will be ok as long as you dont do crazy stuff and dont hit any potholes or somethin
Old Apr 12, 2004 | 02:29 PM
splinter51's Avatar
i ended up ordering the ingalls kit. any good?
Old Apr 12, 2004 | 03:39 PM
spaceman's Avatar
sounds good to me
Old Apr 12, 2004 | 05:09 PM
Riceburner247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_honda_racer &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you do don't get the adjustable upper ball joint ones, I had a friend who had a set and when driving at 40+ the SOB popped out and the whole driver side came crashing down. Go with the the ones that replace your stock anchor bolts, there more adjustable, but you might have to do some grinding to the inner fender lip to get the upper ball joint to tuck up underneath, that is if your slamming it more then 2 inches.</TD></TR></TABLE>
Umm, well, your friend didn't install or get them installed right.
I bought SPC Udjustable Upper Balljoints for my 91 HB. I installed them and they work great. By great I mean no problems and they do their job. I did have to cut into the engine bay for clearance issues, I'm dropped 3", but you'd have to do that with any camber kit if you go that low. Your friends balljoint came apart because the nut on the top wasn't fully tightened.
Old Apr 14, 2004 | 04:55 AM
Default Re: front camber kit (milk)
I can't recall what brand they were, but they were installed on an 91 crx si. And the reason it broke was cause the bolt snapped apart, not because it wasn't tight enough.
Old Apr 14, 2004 | 05:22 AM
techer's Avatar
I used the Ingalls kit on my crx and it worked pretty well... tough to adjust those suckers when its on the alignment rack though. It took a bit of trial and error and was a little time consuming to get them set right. Its almost easiest to remove the upper arm from the shock tower, adjust them a little, and reinstall.
88CRXJ
13
Sep 30, 2009 09:35 PM
AdReNaLiN
Oct 17, 2008 12:00 AM
full Circling
Suspension & Brakes
11
Jan 5, 2005 08:41 AM
Civichatch27
May 31, 2004 12:43 PM
joey1320
Nov 13, 2003 04:16 PM
