Head Studs/Cometic Headgasket on stock Block GSR?
I am getting ready to install my full race turbo kit, but before I do I was wondering If I should install a new thicker .56 headgasket and ARP head studs or just hold off and install now? Is it worth it for reliabity reasons to lower compression using the gasket or should I not worry about it for now.
Thanks for any info.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blueturbo4door »</TD></TR><TR><TD CLASS="quote">both of those items are definately good insurance
Yo, curious, whats the benefit of getting new headstuds? -
I will let you know about the gasket tuesday tho bluesi. -
I will call you most likely...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik »</TD></TR><TR><TD CLASS="quote">Yo, curious, whats the benefit of getting new headstuds? -
factory headstuds can stretch and arp headstuds give you a better tourqe reading because of the way they are made..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfedb18c1 »</TD></TR><TR><TD CLASS="quote">factory headstuds can stretch and arp headstuds give you a better tourqe reading because of the way they are made.. </TD></TR></TABLE>
they are also good when people take heads off frequently. the stud is always threaded in the block, instead of a headbolt that can be misaligned and strip the treads in the block.
arp's, aebs headstuds are super strong and i would recommend them for ANY build!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackout95teg »</TD></TR><TR><TD CLASS="quote">I am getting ready to install my full race turbo kit, but before I do I was wondering If I should install a new thicker .56 headgasket and ARP head studs or just hold off and install now? Is it worth it for reliabity reasons to lower compression using the gasket or should I not worry about it for now.
Thanks for any info.</TD></TR></TABLE>
Yes it is worth it. I would install the HG and Studs before the kit is installed.
TomCurllyFry
Apr 16, 2013 09:25 AM
