v-afc
Old Apr 12, 2004 | 12:32 AM
KOREAN's Avatar
Default v-afc
i heard the vtec on a rsx (base) hits at 2200rpm
can i just get a v-afc and raise the engagement point to 4000, at least? would that affect my engine negatively in any way? i need to be conservative about my gas.
Old Apr 12, 2004 | 12:48 AM
^jefs0ng's Avatar
Banned
Yes you can just change the point of x-over.
Old Apr 12, 2004 | 03:00 AM
Kal's Avatar
Kal
Default Re: (^jefs0nq)
your acceleration will be affected, usually vafc are used for tuning the "true vtec crossover." type s engages at 6k rpm i think?
Old Apr 12, 2004 | 07:56 AM
B18CXr's Avatar
Default Re: v-afc (korean)
there is no need to raise the x-over point on the A3 motor
Old Apr 12, 2004 | 09:02 AM
KOREAN's Avatar
Default Re: v-afc (B18CXr)
i'm just concerned about wasting gas. that's the only reason i want to raise the vtec crossover point.
so how does this i-vtec differ from the regular vtec? sometimes when i go into first gear with more gas, the car accelerates faster. when i go into first softly, the car takes its time. is that where the i in i-vtec comes in?
Old Apr 12, 2004 | 03:36 PM
i3igpete's Avatar
the i parts stands for variable cam timing. but i wouldn't recommend raising the vtec point. the lower cam engagement is only meant for idling and to reduce engine torque at extremely low RPM where it can damage your engine. yes, driving hard at low RPM causes a lot of engine stress. a neat application of my strength of materials class.
raising the vtec higher will severely kill your power. to the point of almost flooring it just pull away in traffic. the engine wasn't designed for those extremely conflicting conditions (wide throttle, low mass flow). in all reality, it will kill your mileage.
CNS2000
Honda S2000
28
May 26, 2005 04:51 PM
civictuned
Aug 1, 2003 04:36 PM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
Wet Nudl
Feb 25, 2002 01:46 PM
