ctr, gsr, type r clusters
Old Apr 11, 2004 | 10:26 PM
egg_baLLa's Avatar
Default ctr, gsr, type r clusters
does the ctr cluster plug and play into the 92-95 civic models?
also is the jdm typr r cluster the same wiring splicing as gsr clusters?
Old Apr 12, 2004 | 03:27 AM
JDMlyfestyle's Avatar
Nope they will not plug and play on a EG. you have to get there plugs and wire them up to the EG wires. there are several write up on these SEARCH is your friend
Old Apr 12, 2004 | 08:43 AM
egg_baLLa's Avatar
Default Re: (JDMlifestyle)
yeah i already know how to do the wires for GSR into an EG. wat i was wondering was if the type r would be the same wiring configuration. sorry if any confusion.
Old Apr 12, 2004 | 08:47 AM
owen_the_soyboy's Avatar
Default Re: (egg_baLLa)
yes,
DC2 ITR = DC2 GSR = DC2 LS cluster wiring.
Old Apr 12, 2004 | 02:36 PM
egg_baLLa's Avatar
Default Re: (owen_the_soyboy)
thanks guys.. also theres no way to put a 96-00 ctr cluster into and EG?
Old Apr 13, 2004 | 04:20 AM
sure you can.
its just as much of a PITA but you can do it.
didnt one of the jdmhondaparts guys do that with a spoon cluster? the green EG?
Old Apr 13, 2004 | 11:18 AM
egg_baLLa's Avatar
does anyone else have some info on the ctr cluster conversion on EG?
Old Apr 13, 2004 | 01:50 PM
ramz7887's Avatar
Get a ITR cluster is alot cheaper then the CTR. Though they both look good. I don't know about how they connect though.
Old Apr 14, 2004 | 02:32 AM
egg_baLLa's Avatar
Default Re: (ramz7887)
anyone else know if ctr cluster would work on an EG? im trying to find out some info before i settle on either the gsr, type r, or ctr cluster.
Old Apr 15, 2004 | 05:31 PM
egg_baLLa's Avatar
bump
Old Apr 15, 2004 | 05:59 PM
Padawan's Avatar
Darth ModerVader
Default Re: ctr, gsr, type r clusters (egg_baLLa)
Why not try a JDM SiR cluster? It will fit perfectly, and the tach's redline is roughly the same (8,200 I believe).
A photo borrowed from inline4:
Modified by Padawan at 10:47 PM 4/15/2004
Old Apr 15, 2004 | 06:11 PM
Mendes's Avatar
Im in the process of doing the GSR Cluster ATM. wiring isnt bad. but take your time and be careful. heatshrink or sauder everything dont use electrical tape. the GSR cluster does not fit perfectly if you dont know so im trying to make something to make it fit better. will post a good DIY in a week or so
Old Apr 15, 2004 | 11:49 PM
egg_baLLa's Avatar
Default Re: (Mendes)
thanks looking foward to ur DIY
Old Apr 15, 2004 | 11:50 PM
egg_baLLa's Avatar
Default Re: ctr, gsr, type r clusters (Padawan)
i already have the SiR cluster. i was looking for something new.
Old Apr 16, 2004 | 12:07 AM
Nah-Roo-Toe's Avatar
Yeah if you do the type r cluster swap, write up a diy thread. Or you could just pm step by step..hahahah
.PLUMMM
Aug 15, 2007 09:12 AM
da6er
Jul 2, 2007 07:41 PM
JDMlyfestyle
Jun 24, 2003 11:00 PM
Malachi
Feb 28, 2002 11:45 AM
SPOON_BeIgHtEeNsEe
Jan 2, 2002 10:25 AM
