1/8 mile track times (2nd trip)
Old Apr 11, 2004 | 09:57 PM
sp00led's Avatar
Default 1/8 mile track times (2nd trip)
Installed Greddy Evo2 on my 99' GSR this weekend which sounds and performs great. I put AEM CAI w/ bypass valve since my last trip to the track as well. So here are my times lookin forward to seein what advice u drag vetrans have for a drag newbie.
Run 1 (droped at 2500rpm)
R/T = .580
60' = 2.458
330 = 6.910
1/8 = 10.466
MPH = 69.77
Run 2 (launched at 4500rpm, mistake i burned all through 1st and jerked 2nd)
R/T ... .624
60 ... 2.475
330 ... 6.966
1/8 ... 10.532
MPH 69.65
Run 3 (didn't rev up till last sec)
R/T .523
60 ... 2.517
330 ... 6.947
1/8 ... 10.453
MPH ... 70.81
First trip times were 10.7-11.2
Old Apr 11, 2004 | 10:04 PM
SUB-0 H23's Avatar
Default Re: 1/8 mile track times (redeyz)
those 60' times suck... i think you should be able to do better w/ practice. you need to feather the clutch and play w/ the gas pedal. it just takes many trials and error. i think you should be able to pull off high 9's to low 10's.
Old Apr 11, 2004 | 10:11 PM
prestonpark's Avatar
Default Re: 1/8 mile track times (SUB-0 H23)
i think ur a canidate for the low 16 second club
Old Apr 12, 2004 | 06:16 AM
1point5CRX's Avatar
Default Re: 1/8 mile track times (civic2003)
i see your mph at 69 which if you can learn to get your 60ft down to 2.3 or 2.2 on street tires, i see no problem why you shouldnt run high 9's, 9.8-9.7 @ 70-72 mph.i know alot of it depends on the track also,it may be a shitty track like our local 1/8th, my best at our crap-hole of a track is 9.8@70 but down at gainsville raceways, it was 9.7@72 with a 15.1@90 1/4, so the track does vary your time a bit, keep pratice going,its all in the launch and shift points
Old Apr 12, 2004 | 04:09 PM
SLR ef9's Avatar
Default Re: 1/8 mile track times (1point5CRX)
i think you can run lowv 15's with that time i ran 15.5 with the same 1/8 with my b16
Old Apr 12, 2004 | 09:48 PM
Danethomp's Avatar
i ran those times in my 90 LS w/ only i/h/e on my very first track run!
TypeRlove
Nov 16, 2004 06:55 PM
B18C1CYA
Jul 26, 2004 08:15 PM
Adi Radoncic
Sep 1, 2002 11:37 PM
stevel
Jun 6, 2002 10:28 AM
mikeSONICGSR
Nov 5, 2001 07:02 PM
