Throw out bearing
Old Apr 11, 2004 | 04:24 PM
dyases's Avatar
Default Throw out bearing
I've done a search and I'm pretty sure my throwout bearing is bad, but the engine/tranny has 199,7xx miles on it and i'm not worried about it lasting too much longer before a swap is in order. What are the potential negative effects of driving with a bad throwout bearing?
Old Apr 11, 2004 | 04:27 PM
Kamin's Avatar
Default Re: Throw out bearing (dyases)
it could eventally cause the clutch to stop working, or cause transmission damage in a real bad scenario.
dyases's Avatar
Default Re: Throw out bearing (Kamin)
generally how long would it last before something happens?
Old Apr 11, 2004 | 04:30 PM
Kamin's Avatar
no way to know. could be 100 miles, could be another 100,000. and i litterally mean that.
Old Apr 11, 2004 | 04:46 PM
Kusai.Nihonjin.Desu's Avatar
When bearings go to crap, bad things can happen. A TO bearing is a 20 dollar part...but honestly you wont know for sure if it's the TO until you replace it. Could be other bearings within the tranny. Get that swap ready!
Old Apr 11, 2004 | 04:48 PM
Kamin's Avatar
Default Re: Throw out bearing (Nihonjin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihonjin &raquo;</TD></TR><TR><TD CLASS="quote">When bearings go to crap, bad things can happen. A TO bearing is a 20 dollar part...but honestly you wont know for sure if it's the TO until you replace it. Could be other bearings within the tranny. Get that swap ready! </TD></TR></TABLE>
thats not true, there are ways to diagnose each bearing inside the transmission even while the tranny is still on the car
example, a bad TOB will make noise at idle, with the clutch engaged (foot off pedal). when you press the clutch in (disengage clutch) the noise will stop. that ALSO could be a bad ISB (input shaft bearing) as those are the only 2 bearings spinning at those times.
Old Apr 20, 2004 | 08:43 PM
JdM_HoNda's Avatar
where id tha input shaft bearing located in tha tranny?
Old Apr 20, 2004 | 08:45 PM
Ricey McRicerton's Avatar
Default Re: Throw out bearing (JdM_HoNda)
Check the thread by BauleyCivic. It's under the mainshaft (between the clutch housing and the input shaft).
And I drove on a noisy ISB for right around 1k before I got around to fixing it.
Old Apr 20, 2004 | 08:48 PM
ABK's Avatar
ABK
Default Re: Throw out bearing (Ricey McRicerton)
I think if the trow out bearing will go, your master cylinder along with slave cylinder might go. That's what happened to my friend.
Old Apr 20, 2004 | 08:53 PM
JdM_HoNda's Avatar
is input shaft bearing where tha axle seal are
Default Re: Throw out bearing (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">I think if the trow out bearing will go, your master cylinder along with slave cylinder might go. That's what happened to my friend.</TD></TR></TABLE>
My TOB went with right about 114k on the car. My MC and SC are fine.
Old Apr 20, 2004 | 09:11 PM
JdM_HoNda's Avatar
ok i have two throw out bearin one is my old bearin that was makin tha noise and i have new on off a friend thia is still new ok here tha fun part how canu tell if either one are good tha one have a smooth spin and tha tha other have a rough spin how canu tell which is good?
Old Apr 20, 2004 | 09:16 PM
The smooth spinning one is the good one. If I were you I'd just go buy a new one from Honda. Honestly, that's like getting used oil.
Old Apr 20, 2004 | 09:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
I was told this, then I went ahead and replaced the TO, ISB, needle bearing...actually I replaced the TO bearing first, and it didnt do the trick...so I replaced the ISB, and the needle bearing(and the TOB again)....did NOTHING. Spent too much time on that crap. But that's my experience anyways.
Old Apr 20, 2004 | 10:32 PM
Gump's Avatar
what kind of noise will the TOB or the ISB make? Mine has been making a noise (with the pedel released) for quite sometime, but both bearings were replaced when I had my clutch and flywheel changed about 10,000 miles ago.
Old May 3, 2004 | 07:10 AM
c1civic's Avatar
i got the same damn problem, and i dont have time to rip out the h form the hatch, so i guess iwill have to wait until summer
Old May 3, 2004 | 07:18 AM
BauleyCivic's Avatar
Risky Business
Default Re: (c1civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">i got the same damn problem, and i dont have time to rip out the h form the hatch, so i guess iwill have to wait until summer</TD></TR></TABLE>
Whats the problem? What are the noises you are hearing?
Old May 3, 2004 | 07:25 AM
BumpinVTEC's Avatar
Default Re: (BauleyCivic)
i hear constant clinking when my cars idleing and when i push the clutch in it gets louder, i have a exedy street/race clutch the ones with the shitty pressure plates...is this clicking sound related to my throw out bearing?
Old May 3, 2004 | 07:29 AM
Default Re: (BumpinVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BumpinVTEC &raquo;</TD></TR><TR><TD CLASS="quote">i hear constant clinking when my cars idleing and when i push the clutch in it gets louder, i have a exedy street/race clutch the ones with the shitty pressure plates...is this clicking sound related to my throw out bearing?</TD></TR></TABLE>
It's definatley not your input shaft bearing. The noise would go away when you pushed the pedal in if it were that.
Old May 3, 2004 | 11:39 AM
c1civic's Avatar
Bauley civic, thanks for the help
on mine when im sittin in neutral with the clutch pushed in..it idles perfect no noise or anything
but when i sit at idle with the clutch NOT pushed in i here almost like somehting is barely grinding or rubbing.
i just got my car togethere that i have been working on for six months, i really hope i dont have to tear the thing back down...could it be the input shaft, and if so how do i check it
Old May 3, 2004 | 01:16 PM
crazy eyez killa
Guest
Posts: n/a
mine makes a squaking noise sometimes, just like my last 3 throuwout bearings.
I have bought 2 from Honda, and 1 from Napa, all 3 ******* squeak
Its not a bad noise, just an annoying squeak when the clutch pedal is out, loudest when the car is cold.
I can also make the sound stop by playing with the clutch pedal a little bit.
Old May 3, 2004 | 01:42 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
mine went for a long time before i put my swap in her.. dont worry about it.
and mine was GONE.. like super grinding loud.. horrible noise.
TravisBiggie
Honda Civic (2001 - 2005)
Nov 25, 2012 02:00 PM
Patman
Jul 30, 2008 08:36 PM
Ek4_honder
Sep 27, 2007 06:48 PM
teg01type-r
Mar 19, 2007 07:12 PM
