98 auto civic-90 integra
i got an auto tranny in a civic and wanna put a B18A1 into it...i know its possible but is it really worth the time? im going from a hydrolic clutch to cable clutch...do i need to buy anything for this conversion? any help will be helpful
What do clutches have to do with swapping automatic engines? Do you mean rod-to-cable shift linkage swap? In that case, if that is what you mean, you need the Integra shifter assembly and you'll need to cut some holes for the cables to run through. Aside from that it's just another engine swap.
ok, i think i know what your talking about...thanks for the quick feed back, if you are anyone else have any tips, would be helpful, i wont be doing this swap for another month...just getting off the information i can at the moment
