H22 civic header? thoughts.....
http://www.imagineengineering.com/products.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Gains are as much as 13 horsepower and 9 ft-lbs of torque to the wheels</TD></TR></TABLE>
Re: H22 civic header? thoughts..... (slowhatch4now)
I have it
Its an awesome header, but a bitch to get in
I recommend it
EDIT: and thats 13 hp OVER the DC Sports
I recommend it
Re: H22 civic header? thoughts..... (=GAMEOVA=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= »</TD></TR><TR><TD CLASS="quote">hows the clearance on this header?</TD></TR></TABLE> it's supposed to have more clearance than other headers.......does anyone know a place to find these cheaper? i would be putting it on a EK hatch
Hugs the Oil pan
If you are dumped, that might be another story
Hugs the Oil pan
Re: H22 civic header? thoughts..... (speedinghatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch »</TD></TR><TR><TD CLASS="quote">If you are dumped, that might be another story </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinghatch »</TD></TR><TR><TD CLASS="quote">CLiff Notes: IF you lower your car too much, you hit things</TD></TR></TABLE> i think that's the case with anything....but, i think it prolly has more ground clearance than any other header excluding the stock exhaust manifold.....
Re: H22 civic header? thoughts..... (94_HATCH)
I'm currently running the header , The header truelly gave nice power throughout powerbands. A bitch to get on and it hangs low, prolly about 1"-1 1/2 " under the oil pan. If your running 15's dont even think about it. I have my car jacked up high and I still hit bumps in the road. I'm thinking about making a skid plate . The I.E. header also rattles like a **** and could of been a better design.
Modified by 93hatched_projekt at 7:50 PM 4/11/2004
Darth ModerVader
Re: H22 civic header? thoughts..... (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Bottom line: Best header for an H22A in an EG. Period. Buy it if you're serious.</TD></TR></TABLE>
I think that might be a bit of a stretch. "Serious" headers don't have formed collectors, and the build quality appears to leave a bit to be desired. For the money, I'm sure it isn't a bad option, but there are better pieces out there.
Unceasing Measure
Re: H22 civic header? thoughts..... (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I think that might be a bit of a stretch. "Serious" headers don't have formed collectors, and the build quality appears to leave a bit to be desired. For the money, I'm sure it isn't a bad option, but there are better pieces out there. </TD></TR></TABLE>
I'm sure someone makes a better header for an H22A in a Prelude, but with the fitment issues and all, and this header being specifically made for an H22A EG, this is the best job-specific header you can buy for your swapped setup. It makes hellish power over the DC unit throughout the powerband, it looks pretty good and the clearance is nice.
I do agree that it could be manufactured a little nicer, but power is power and I can't argue with a dyno sheet .
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">I'm sure someone makes a better header for an H22A in a Prelude, but with the fitment issues and all, and this header being specifically made for an H22A EG, this is the best job-specific header you can buy for your swapped setup. It makes hellish power over the DC unit throughout the powerband, it looks pretty good and the clearance is nice.
I do agree that it could be manufactured a little nicer, but power is power and I can't argue with a dyno sheet .</TD></TR></TABLE>
True. I'd be interested to see a back-to-back done with SMSP's H22 header. His was dynoed a while ago on a H22A4, and made ~206 whp with relatively few mods (the header was tested "open", but otherwise the engine had basics bolt-ons and only a FPR for fuel tuning). While his H22 header isn't designed specifically for this hybrid application, my understanding from his posts is that it does fit, and his quality is second-to-none. Of course, it's more expensive, but the pricing he indicated at that time was for a stainless piece with a complete bolt-up collector flange and merge collectors throughout. Again though, if the gains from the IE unit are accurately represented by their dyno graph, it is a good performer for the money.
GAccord
17
09-15-2004 10:17 AM
HotWheelz
11-02-2003 03:11 PM
