Alpine and punch amps for sell
Punch 100ix - $150 This amp has a built-in cross over.
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4 Volts
Mono into a 4ohm Load.............................................. 420 Watts
Per channel into a 2 ohm Load.....................................200 Watts
Per channel into a 4 ohm Load.....................................110 Watts
Continuous Power Rating (Competition Standard) - Measured at 12.6 Battery Volts
RMS continuous power per channel,
both channels driven into a 4 ohm load
from 20 to 20,000Hz, with less than
0.05% Total Harmonic Distortion (THD)..........................50 Watts
both channels driven into a 2 ohm load
0.1% Total Harmonic Distortion (THD)...........................100 Watts
RMS continuous power mono into a,
4 ohm load from 20 to 20,000Hz, with
less than 0.1% Total Harmonic
Distortion (THD)............................................. ...........200 Watts
Dimensions(WxLxH)................................. ....9-5/8"x11-5/8"x2-5/8"
Bandwith.......................................... ........10Hz to 200kHz +-3dB
Damping Factor @ 4ohm.................At output connector - Over 200
Frequency Response...20Hz to 20kHz +-1.0dB/10Hz to 100kHz +-0.5dB
Slew Factor............................................ .....................50 Volts
IM Distortion (IHF)............................................. .Less than 0.05%
Input Sensitivity...................................Vari able from 150mV to 3V
Fuse Rating and Type.............................................. ..40amp ATC
Equalization...................................Bas s: +18dB Maximum at 45Hz
Treble: +12dB Maximum at 20kHz
Alpine MRV-F300 - $100 ea. This amp has a built-in cross over.
RMS Power(at 12 V, 20 - 20k Hz)
Per Channel into 4 W ...................... 30W x 4 (0.08% THD)
Per Channel into 2W ......................... 40W x 4 (0.3% THD)
Bridged 2 Channel into 4W ............. 80W x 2 (0.3% THD)
Dynamic Power(at 14.4V, 20 - 20k Hz)
Per Channel into 4 W ...................... 50W x 4 (0.08% THD)
Per Channel into 2W ......................... 60W x 4 (0.3% THD)
Bridged 2 Channel into 4W ........... 120W x 2 (0.3% THD)
Frequency response ..................... 10 Hz to 50 kHz (+0, -1 dB)
Signal-to-Noise Ratio .. 100 dBA(referenced to rated power)
Input Sensitivity (for rated power)
Line Inputs .......................... 200mV-4V (500mV at detent)
.................................................. ....................... (1.0V at center)
Slew Factor .................................................. .......... Greater than 5
Input impedance .................................................. ......... 10k ohms
Speaker Impedance .................................................. ......................
.......................... 4 or 2 ohms (stereo) or 4 ohms (bridged)
Dividing Network Frequency and Slope ........... 50 ~ 200 Hz
.................................................. .................. 12 dB/ Oct. Slope
Power Requirements .............. 11-16V DC (Negative ground)
Dimensions(WxHxD) ....................... 9-7/16"x2-1/16"x10-5/8"
.................................................. .................... (240x53x270mm)
Weight............................................ ........................ 7lb 4 oz.(3.3kg)
Alpine MRV-T300 - $50 This amp has a built-in crossover.
RMS Power (at 12V, 20-20kHz)
Per Channel into 4W ....................... 30W x 2 (0.08% THD)
Per Channel into 2W .......................... 50W x2 (0.3% THD)
Bridged 1 Channel into 4W ........... 100W x 1 (0.3% THD)
Dynamic Power (at 14.4V, 20-20kHz)
Per Channel into 4W ...................... 50W x 2 (0.08% THD)
Per Channel into 2W ......................... 75W x 2 (0.3% THD)
Bridged 1 Channel into 4W ........... 150W x 1 (0.3% THD)
Frequency Response ....................... 10Hz to 50kHz (±0, -1 dB)
Signal-to-Noise Ratio . 100dBA(referenced to rated power)
Line inputs .......................... 200mV-4V (500mV at detent)
Slew Factor .................................................. ........ Greater than 5
Input impedance .................................................. ....... 10k ohms
Speaker Impedance .................. 4 or 2W (stereo) or 4W mono
Dividing Network Frequency and Slope ............... 50-200Hz
.................................................. ............... 12dB/Octave Slope
Power Requirements ............. 11-16V DC (negative ground)
Dimensions (WxHxD) .................. 9-7/16"x2-1/16"x5-15/16"
.................................................. .................... (240x53x150mm)
Weight............................................ ..................... 4lb. 3oz.(1.9kg.)
Or all (4) Amps for $300
AOL IM me or IM on honda-tech or email me
