Drag manifold + tial wg with .5 spring is overboosting
Old Apr 10, 2004 | 03:00 PM
PolySquared's Avatar
Default Drag manifold + tial wg with .5 spring is overboosting
Previously, i was running drag manifold with deltagate wg. I had problems of overboosting .5 bar (accorinding to my gauge). Its overboost at high rpms (over 6k rpms) than it starts spiking or bogging. I thought it was the wastegate, so i upgraded to a 38mm tial wastegate with a .5 spring. After the upgrade, I still overboost .5bar and slight bog or spike at higher rpms. Do i have to change my manifold too?
Old Apr 10, 2004 | 05:45 PM
AirWaveGT's Avatar
Default Re: Drag manifold + tial wg with .5 spring is overboosting (PolySquared)
the drag manifold has poor wastegate placement so that is probably your problem. is it possible that your boost gauge is reading wrong?
Old Apr 10, 2004 | 06:58 PM
hulkhb's Avatar
Default Re: Drag manifold + tial wg with .5 spring is overboosting (AirWaveGT)
^^^ like dood said its WG placement on the drag mani, it BLOWS
Old Apr 10, 2004 | 09:45 PM
Dengar's Avatar
Default Re: Drag manifold + tial wg with .5 spring is overboosting (hulkhb)
https://honda-tech.com/zerothread?id=802961
Here is a link to a thread started by Nick the FI moderator about this problem. Drag manifolds are known for boost creep because of the wg placement as stated before, but in that thread there are some solutions to the problem.
Old Apr 11, 2004 | 12:17 AM
underb00steg6's Avatar
i run the same set up.Drag manifold with a 38mm wg. and its .5 bar.I dont have any problems.May be your gauge is bad?And how much are you over boosting?
Old Apr 11, 2004 | 02:37 AM
Default Re: Drag manifold + tial wg with .5 spring is overboosting (JeDgM6)
Im overboosting about to .7bar at high rpms.
Absentmind
Mid-Atlantic (Sales)
Sep 29, 2008 05:53 PM
delsinner13
Aug 10, 2006 07:27 AM
ILOVEGIRLS
Feb 19, 2002 11:34 AM
