Tilton Clutch Master Cylinder?
Old Apr 10, 2004 | 11:01 AM
jdmcivicferio's Avatar
Default Tilton Clutch Master Cylinder?
Has anyone tried using a tilton clutch master cylinder yet, when they upgraded there clutch? My hydrolic system is to weak to handle the pressure plate, I have tried a lot of stock honda ones and they keep braking, I am going to try a prelude master and if that doesn't work, then I have problems.... So I guess Tilton is the way...., anyone tried one?
Old Apr 11, 2004 | 02:06 PM
Default Re: Tilton Clutch Master Cylinder? (jdmcivicferio)
so no one has tried one?
Old Apr 11, 2004 | 02:12 PM
TurboBumblBee's Avatar
what type of clutch and pressure plate are you using? tilton?
btw, those tilton clutches are badass..
Old Apr 11, 2004 | 05:06 PM
Default Re: Tilton Clutch Master Cylinder? (Boostfedb18c1)
i'm actually using a custom made clutch/pressure plate, that has 2500psi clamping force, doul diaphram sprung 4 puck, the clutch holds amazing but it makes a short life of my hydrolic system, so I was looking into upgrading the master cylinder
Old Apr 21, 2004 | 12:16 AM
mskibbz-T's Avatar
Hrmmm, You may want to talk to Kyle @ WiredSpeed.com, he carries Tilton and may be able to help you out with some advice
Old Apr 21, 2004 | 09:27 AM
Flamenco-T's Avatar
Default Re: Tilton Clutch Master Cylinder? (mskibbz-T)
I have seen one in person, they are definitley a master piece. I knwo a few around here that has one, but never actually felt the pedal pressure and etc.
I carry Tilton as well, but have not sold any system with the Master cylinder yet.
Stan
Old Apr 21, 2004 | 10:19 AM
Kataku2K3's Avatar
Default Re: Tilton Clutch Master Cylinder? (Flamenco-T)
We run the Tilton master cylinder/throwout bearing on a couple of our cars and I love it, feels like an ACT heavy duty pedal. Haven't had any problems yet. Here's the link if you wanna read up a little.
https://honda-tech.com/zero...age=1
EDITED: because I can't spell things right...
Modified by Kataku2K3 at 9:03 PM 4/21/2004
Old Apr 21, 2004 | 07:51 PM
Default Re: Tilton Clutch Master Cylinder? (Kataku2K3)
I ended up just building my own hydrolic system thanks
Old Sep 21, 2011 | 09:07 AM
typeflex's Avatar
whatever happened to these?
jtran21
Honda Civic (2001 - 2005)
Mar 11, 2013 08:32 PM
jaywo_23
Oct 11, 2007 08:49 PM
nnightingale
Sep 23, 2007 09:39 PM
Surestick
Aug 23, 2006 10:56 AM
ViZ
Sep 18, 2003 12:19 PM
