Need Help, Where does the Vtec Oil Pressure pin go in the ECU Clip?
Old Oct 27, 2001 | 07:46 AM
JohnX6's Avatar
Default Need Help, Where does the Vtec Oil Pressure pin go in the ECU Clip?
I have a 97 DX and i'm trying to add the wires in to Wire up VTEC. So i added in VTEC, Knock and someone told me i need to wire up VTEC Oil PRessure, where in the clip is this? indicate please by big Gray clip, Big blue clip, small blue clip, cause i forget which clip is clip a, b, c. i looked in the Hybrid Board, but it doesn't say anything about it....Thanks
Old Oct 27, 2001 | 01:05 PM
rainforest's Avatar
Default Re: Need Help, Where does the Vtec Oil Pressure pin go in the ECU Clip? (JohnX6)
go to hybrid honda and find out.
Old Oct 27, 2001 | 01:50 PM
JDMspecEG's Avatar
New User
The plugs that you really use are A, C, and D. Plug B is for automatics. The VTEC press pin is C15, and it is the plug that is second from the right (the blue one) on the ECU. I think you're also goin to have to change ur IACV pin if you haven't already since the DX uses a rotary style 3 pin IAC and any other motor uses the linear type. If you need to do so take ur plug A (the big gray one) and move pin A14 to A12, that's ur IAC + and you will also need to modify the engine side of the harness with a two pin connector. And last if you are doin a GSR swap with a stock intake manifold you'll have to add the signal wire for the IAB solenoid, that's pin A26. Good luck!
Old Oct 27, 2001 | 06:09 PM
Katman's Avatar
hope this grapic of mine helps..
oooooooops my baad.. this image is for 92-95 civic/94-95 integra's sorry!
I'll make an Obd2 one ...some day..
-k
[Modified by Katman, 7:10 PM 10/27/2001]
CivicxTree754
Apr 27, 2011 11:51 AM
DJ_SaNdOz
21
Jan 19, 2005 07:49 AM
hatchback_al
May 31, 2004 03:05 AM
