Si coilovers into 1999 Integra
Old Apr 9, 2004 | 08:03 PM
christhereefer's Avatar
Default Si coilovers into 1999 Integra
Will Tein FLEX with EDFC from a 99 Si fit into an 99 Integra LS ?
Old Apr 9, 2004 | 09:39 PM
liam821's Avatar
25 Year Member
Default Re: Si coilovers into 1999 Integra (christhereefer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by christhereefer &raquo;</TD></TR><TR><TD CLASS="quote">Will Tein FLEX with EDFC from a 99 Si fit into an 99 Integra LS ?</TD></TR></TABLE>
The fronts fit - but the rears will not. Not without modifications atleast. The rear swaybar mount is narrower on the 99 SI. So to fit it on an integra you need to grind some material off of your bushing on your rear LCA to make the suspension fit.
It might be easier to sell the SI kit and just buy one for your integra.
liam
Old Apr 9, 2004 | 10:45 PM
chads's Avatar
Default Re: Si coilovers into 1999 Integra (liam821)
are you sure? i put gc coilovers on my 00si from my friends 95 gsr
Old Apr 9, 2004 | 10:48 PM
TorganFM.'s Avatar
Default Re: Si coilovers into 1999 Integra (chads)
GC coilovers as in just the sleeve or both the sleeves and the shocks they go around?
Old Apr 9, 2004 | 10:51 PM
chads's Avatar
Default Re: Si coilovers into 1999 Integra (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">GC coilovers as in just the sleeve or both the sleeves and the shocks they go around?</TD></TR></TABLE>
sleeve and spring, i have stock shocks, i guess thats what you mean
Old Apr 10, 2004 | 11:35 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chads &raquo;</TD></TR><TR><TD CLASS="quote">are you sure? i put gc coilovers on my 00si from my friends 95 gsr</TD></TR></TABLE>
Yea and i bet the rears where it connects to the LCA was loose. Did you use a few washers?
liam
Old Apr 10, 2004 | 09:04 PM
expressivepinoyboy1's Avatar
hey ryan will it fit loks..
Old Apr 10, 2004 | 10:41 PM
Evs-One's Avatar
Solbros Owns Me
because the Teg/EG LCA's have a wider shock fork than the 96-00 Civics....meaning the EG's fit over EK's, but not the other way around.
Just use a grinder and take off some bushing....I did 2 sets of EK Buddy CLubs coilovers onto EG LCA's and my current Koni Yellows are for an EK also
skiwithcars
Suspension & Brakes
Mar 30, 2005 05:28 PM
adamryan1
Jan 15, 2005 02:20 PM
fst teg 1
Aug 26, 2004 09:31 AM
mexipino26
May 24, 2002 11:33 AM
