oil pressure
Honda engines run aboit 10 psi oil pressure on idle
and they need to see around 50 psi around 3k rpms
all engines i have seen for honda follow this rule
and btw, oil pressure is high when engine is cold and oil is cold
once it gets a lil warmer and softer, it looses pressure..
plus, oil pumps are supposed to be opening their releif valves around 75-80 psi anyhow..........
when i first start my car when its cold itll stay at around 80psi. then when it warms up fully ill have about 25psi at idle(900rpm) and it will go up to about 83psi then the valve will open and it will fall back to about 78psi and stay there until vtec where it falls ~10psi instantaneously. it will also climb maybe 1 or 2psi per 1000rpm all the way to redline.
my oil pressure line is T'd off my ls/vtec line also
USDM 4G VTEC
Sep 3, 2003 08:26 PM
