my lowering plans
Old Apr 8, 2004 | 10:27 PM
blackriceman's Avatar
Default my lowering plans
im gonna get some prokits for my 6gen and run on stock shocks
after i get it installed and aligned , should i consider a camber kit depending on the amount of camber ? if so what degree of camber would i need to start worrying about getting the kit
i dunno if a 1.5 inch drop is enough to need the kit, but then ive heard about tire wear
should i worry about one side dropping lower than the other ?
http://www.honda-acura.net/for...rokit
Old Apr 8, 2004 | 10:36 PM
Default Re: my lowering plans (johneyou)
o wait actually i found somethign abuot it in the guide to accords
does anyone have any experience with stock shocks n eibachs ? will my camber be ok after i install them? cus im really not wanting to pay extra for the camber kit
Old Apr 8, 2004 | 10:51 PM
.bagged's Avatar
Good job checking the guide..It has some general info that can answer some questions..generally you will not need a camber kit unless you go lower than 2"..so at 1.5 you shouldnt have anything to worry about..As far as changing your struts out it is def. something you should look into for the future...
Old Apr 8, 2004 | 11:53 PM
syclone's Avatar
it will be tolerable.. your front will remain close to 0 camber, but the rear will end up around -1.5 to -2.0 which is still somewhat acceptable.. when you take your car in for alignment, ask them to set the rear toe to '0'
i had prokits and stock shocks before i upgraded.. my shocks started noticeably going out a little after a year..
however, i have sh*tty roads here which are quite punishing.. the life of your stock shocks will vary according to your road conditions..
Old Apr 8, 2004 | 11:57 PM
Riceburner247's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johneyou &raquo;</TD></TR><TR><TD CLASS="quote">cus im really not wanting to pay extra for the camber kit</TD></TR></TABLE>
They're not that expensive. My 1.5 - 3 degree kit cost $180. I had to special order and pay for shipping too. 0 to 1.5 degree shouldn't be more than $100. If you don't pay the $100 for the kit, you'll pay more than that for the tires you'll wear through.
Old Apr 9, 2004 | 08:40 AM
what do u think of S techs
what r some other springs that r tested on stock struts
Old Apr 9, 2004 | 10:45 AM
Beach Accord's Avatar
screw riding on stock struts.....might as well just save up and do things right. this way, you wont hafta keep dropping the suspension and installing new.
get some koni yellows (pssst....im selling some) or some tokico illuminas.
-chris
Old Apr 9, 2004 | 11:13 AM
Default Re: my lowering plans (Beach Accord)
if i do springs n shocks one at a time
it would be better if i start with stock shock + aftermarket springs right ?
not aftermarket shocks + stock springs right?
my problem is money right now
Old Apr 9, 2004 | 11:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by johneyou &raquo;</TD></TR><TR><TD CLASS="quote">if i do springs n shocks one at a time
my problem is money right now </TD></TR></TABLE>
no.....thats just pointless.....why do something half ***? if your problem is money right now, then doing suspension on your car should not be your goal. im sure you just want better handling on your car, and thats great. but in my opinion, when you do something, do it right and complete. so just keep saving up until you have money for springs AND dampers. you will be much happier in the long run. do ya feel me?
-chris
Old Apr 9, 2004 | 11:54 AM
how about if i just go for the lower look hehe
arent the springs the ones that cause the lowering or do the shocks help lower the car also ?
Old Apr 9, 2004 | 12:15 PM
ive heard of shocks lowering the car by like 2 cm but r there ones that go even lower than that
do the lowerings from shocks just come from the adjustable perches they have or is it somehting else?
also waht shocks work with eibach prokits ive read about koni yellows going well with them but do tokico hp's work with prokits?
Modified by johneyou at 9:37 PM 4/9/2004
Old Apr 9, 2004 | 01:25 PM
o yea and ive read on forums that s techs are ok for stock struts,
on their site it doesnt say anything about it tho like on eibachs site they say their prokits r tested
so i think i might just go with the eibachs just to be safe
Old Apr 9, 2004 | 03:42 PM
tommymoose's Avatar
I'm in the same situation as this guy except i have a 5th gen. One of my problems is money, but if that was the only problem i would definately just save up and do it right. My other problem is that I'm most likely going to have the car for only another year and a half because I will be going to college and most likely it will be in Boston or another big city and I wont want/need a car while I'm there. I want the handling improvement, and if I can do that for $200 dollars, I will. Spending $750 dollars is a whole nother story because as i mentioned above, I'm only going to have the car another year and a half, and I need to save money for school. Do you think the pro-kit would be good to use for a year and a half until i part out and sell the car? What if I decide to keep the car while I'm at school and then I want to put in some struts... I'd asume that wouldnt be a problem, but I dont know. Any help is appreciated. By the way, that beginners guide is great...thanks
krysted9354
Suspension & Brakes
May 18, 2009 12:49 PM
exratedaccord93
Sep 8, 2006 06:32 AM
vtec_head
10
Aug 9, 2006 03:27 AM
lazyxazianxboi
Nov 1, 2004 08:32 AM
