transmission problems
Old Oct 26, 2001 | 04:02 PM
jteasy's Avatar
New User
Default transmission problems
My car shudders when I engage the clutch in first gear, it feels like it wants to die, like I am not giving it enough gas, but I am. And it is now hard to shift from gear to gear, is it time for an overaul, or is it a clutch spring, or syncros, or what?
Also, when the syncros go bad, what part of the transmission needs to be replaced, or fixed.
Old Oct 26, 2001 | 06:17 PM
gsr camel's Avatar
Default Re: transmission problems (JTEASY)
hmmmmm never heard this type of complaint I would guess it would be clutch related but thats just a guess good luck on findin the prob tho!
Old Oct 26, 2001 | 06:44 PM
stick's Avatar
check ur clutch fluid (small reservoir next to master cylinder)
u may be low in fluid. replace with honda OE brake fluid
as for synchros, usually u get a grind when shifting into a specific gear
u can replace one at time but usually its easier to do all of them.
hope its nothing major, there goes ur alarm, tint,etc....if it is
go to dealer for them to check out ur clutch
Old Oct 26, 2001 | 07:55 PM
jteasy's Avatar
New User
Default Re: transmission problems (stick)
I got the tint, but I think it is screwed, I will check the fluid level in the morning.
Old Oct 29, 2001 | 08:32 AM
allenp's Avatar
See this link:
https://honda-tech.com/zerothread?id=81257
It's a post I made a week ago, that may enlighten on some basic questions. It doesn't directly answer your ? but it may help.
Old Oct 29, 2001 | 03:59 PM
Phat Corolla's Avatar
New User
Default Re: transmission problems (allenp)
I have a little paper on clutch symptoms and the explainations, but it's at home. I'll maybe try to scan it later and put it up.
Old Oct 29, 2001 | 06:08 PM
jteasy's Avatar
New User
Default Re: transmission problems (Phat GS-R)
that paper would be helpful. thanks
Old Oct 29, 2001 | 07:10 PM
New User
I can scan it in tomorrow. My scanner here is broken.
Old Oct 30, 2001 | 03:47 AM
jteasy's Avatar
New User
thanks for all the help. Would having the wrong transmission fluid in the tranny cause difficult shifting.
Old Oct 30, 2001 | 07:10 AM
New User
Yeah, having the wrong fluid does make it hard, but not THAT hard. I was running plain 5w30 for a week without anything breaking. I switched to Honda MTF as quickly as possible, however. I would change to MTF if you haven't already.
Old Oct 30, 2001 | 07:17 AM
New User
Hmm...after reading the whole post, I have some stuff to add.
I would say that the symptoms would point to either a broken clutch spring or a broken release system somewhere. Check your master cylinder and slave cylinder first to see if everything is working there, but you may have to drop your transmission and replace the clutch. If you are mechanically inclined, you can probably do the clutch yourself. http://www.c-speedracing.com has a great tutorial on this. If you have any questions, post them here or IM me, as I have gone thru this same type of situation a while ago.
Old Oct 30, 2001 | 08:42 AM
jteasy's Avatar
New User
it has been about two weeks, and I am going up to the shop that changed it the first time, and ask them to change out the fluid to either GL3 which is what they were supposed to put in, but they were out, or have them put in the honda stuff.
Old Oct 30, 2001 | 10:25 AM
New User
Have them put in Honda MTF. This is one of those things where aftermarket is not necessarily better.
Old Oct 30, 2001 | 10:30 AM
DavidGSR's Avatar
I agree with Phat GSR. Probably a broken spring retainer. Original clutch? The symptoms sound like that. If the master / slave cylinder don't pan out, you will have to drop the tranny to diagnose. In that case, just plan to replace the clutch.
Old Oct 30, 2001 | 10:32 AM
New User
Default Re: transmission problems (DavidGSR)
Pretty much.
Old Oct 30, 2001 | 11:30 AM
jteasy's Avatar
New User
anybody have info on how to locate the master and slave cylinder, and how to check them, to make sure they are working. my fluid levels are fine, but if it isn't releasing all the way, then the slave could be the problem, but I am not sure how to tell if it is or isn't working correctly.
Old Oct 30, 2001 | 11:41 AM
junglistgsr's Avatar
when you say isnt releasing all the way, do you mean the clutch? because my clutch doesnt feel like its releasing all the way sometimes and i never have replaced my slave cylinder, if the slave cylinder causes a problem like that i think im going to do it this weekend.
Old Oct 30, 2001 | 06:09 PM
jteasy's Avatar
New User
Default Re: transmission problems (junglistgsr)
there is an adjustment that you can make on the heigth of the pedal, you can read about it in a haynes manual. However, upon further inspection of my symptoms, I have figured that it is just a worn spot on the flywheel and the synchros are gone, and burned up, I figured this out because it is only hard to get into gear, and it is harder to get into gear the faster I go, so the speed difference between the tranny shaft and the engine revs is drastically off, due to the syncros are worn out, and making it harder to shift the faster I go. I also read that when the slave cylinder goes out, it causes a complete failure and loss of ability to shift at all, and when you put it in gear, whether or not the clutch is ingaged, the car will stall.
Does anybody know where the cheapest place to buy a type R clutch and flywheel would be. thanks
Old Oct 30, 2001 | 06:12 PM
stick's Avatar
so ur clutch/slave cylinder/master cylinder are shot??/
u can go to http://www.ahmotor.com for all ur OE needs.
i would get the whole ITR set up>clutch and flywheel.
m.c and s.c are the same tho.
Old Oct 30, 2001 | 06:24 PM
New User
What do you mean by that??? Are you saying that they are the same mechanism?? If so, then I'll have to disagree. If not, please specify what you meant. Thanks!
Old Oct 30, 2001 | 06:34 PM
leechungsr's Avatar
mc and sc can be pretty expensive, there are alternative brands out there..and it's not like they're bad..
Old Oct 30, 2001 | 07:07 PM
Sloth's Avatar
New User
Default Re: transmission problems (LeeChun GSR)
i think he is saying the clutch master cylinder and slave cylinder or the same on any model integra
ohh and you guys that hear a little grind while shifting at high r's and the shifter feels harder, this is what happend to me. i thought it was my snycros.
http://www.geocities.com/mastasloth/Clutch.html
[Modified by Sloth, 4:09 AM 10/31/2001]
Old Oct 30, 2001 | 07:12 PM
New User
Default Re: transmission problems (Sloth)
Oh my bad. Sorry if I came off as an ***...I didn't mean to.
gosu08
Aug 30, 2010 02:42 PM
jwshilli
Jul 14, 2009 03:02 PM
niceprelude
Nov 7, 2008 10:22 AM
shiux
Mar 19, 2006 06:53 PM
k20em2
Mar 19, 2005 04:53 PM
