civic rear disc brake swap
Old Oct 26, 2001 | 03:09 PM
tcc1577's Avatar
Default civic rear disc brake swap
does installation of 90 thru 93 Integra rear discs to an 89 civic hatchback require use of larger than 14" wheels? Also looking for a 5 spd. / differential swap that will get me 4.40 final drive or lower (higher numerical ratio)? I know the crx ratio is 4.40. Can I do better with any other model trans?
Old Oct 26, 2001 | 04:11 PM
Dank26's Avatar
Default Re: civic rear disc brake swap (tcc1577)
ON the teg brakes you can go 14inch and up.No 13inch wheels
HTH
-Dan
Old Oct 26, 2001 | 04:57 PM
tcc1577's Avatar
Thanks for the info. Any body know about the trans/diff possibilities?
Old Oct 27, 2001 | 06:28 AM
keithv's Avatar
If the 99 rear Teg brakes are the same size as the 90-93 Teg brakes, I can test fit a set of 13" steelies on my Teg...
I'll probably do it anyways, just for my own reference.
I'll let you know how it goes...
Old Oct 27, 2001 | 08:09 AM
t04ef's Avatar
New User
Default Re: civic rear disc brake swap (breaka_1_9)
i know for sure you can run 13" wheels on integra rear brakes.
My crx has them right now.
integra rear brakes, stock 13" wheels, never had a problem.
Old Oct 27, 2001 | 09:08 AM
tcc1577's Avatar
Default Re: civic rear disc brake swap (t04ef)
Thanks for all the quick responses to the wheel size question. Big help. Did the teg control arm / rear disc setup bolt into your crx with no modifications/problems other than e-brake length?
Old Oct 27, 2001 | 10:27 AM
JohnnyM's Avatar
They will bolt in no problem. Check out this link http://www.geocities.com/CapitolHill.../Disc2Drum.htm
Old Oct 28, 2001 | 01:31 AM
crxgurlllll's Avatar
only the EX upgrade requires 14" rims and wont fit any crx rims
Old Oct 28, 2001 | 07:32 AM
tcc1577's Avatar
Again, thanks for all the feedback. Does anyone know just how much the teg swap will increase the track width?
Old Oct 28, 2001 | 08:22 AM
Dank26's Avatar
Default Re: civic rear disc brake swap (eraser)
When you say"only the EX upgrade requires 14" rims" are you refering to 90-91 EX or 92-95 EX?
Just curious...I have integra brakes 90-93 on the front of my HF crx.
I used the 90-91 EX knuckles inorder to fit the integra brakes.
If you're refering to the 90-91 EX 4dr. about "requires 14"rims"
How can you fit 13" rims on integra brakes.
the front rotors for both cars are 10.3 inch.
wouldnt both civic EX and Integra "require" 14s for clearence of brakes?
Just curious....Thanks
nicky352
Dec 20, 2010 03:43 PM
SPL KID
Apr 26, 2005 03:55 PM
Ckleijne
Apr 20, 2004 10:45 PM
B HATCH
10
Apr 15, 2003 09:39 AM
