sol or eg hb
which car would you get a 94-97 vtec del sol or a 92-95 hb si (probably or cx).
i plan on putting in a b20 block but unsure if i want to go vtec or turbo. also what head would you run on the b20 if it were NA or FI. thinking about probably a b16 head on the NA because i heard it flows better but i am not sure what head to run if i went FI.
almost no sense in asking that questoin on this forum, everyone will say the hb, bc most people on here drive them and they weigh a good bit less, all depends on what u like in a car and what you are looking to do with the car, and yes the b16 head is one of the better flowing heads
well if you're planning on doing the b20 block, a good idea would be get the Sol... use the b16 head on the b20 block. many ppl prefer the hatches though, so you're going to get biased opinions. i like them both... my hatch is a bit stiffer though, then again i did more suspension work on my hatch then i ever did on my Sol. but at least you've got a good platform to start w/ your b20 block.
eagleclawracing
Jul 5, 2005 08:53 PM
bonestock92si
Apr 3, 2004 05:58 AM
