what type of size housings should i be lookin for in a turbo
Old Apr 8, 2004 | 06:36 AM
bgsxyguy's Avatar
Default what type of size housings should i be lookin for in a turbo
im kinda confused on what size housings i should be lookin for like if the compressor housing should be smaller then the turbine housing or the other way around or what not because i know that the smaller the housing will produce better spool up and create better low end power but i dont kno what to look for and also what about trim sizes i should look at if anyone could help me out that will be great
Old Apr 8, 2004 | 06:54 AM
tgreaves's Avatar
Default Re: what type of size housings should i be lookin for in a turbo (bgsxyguy)
Well what car do you have and what motor do you have in it.. Also what do you have done to your motor..
Old Apr 8, 2004 | 08:23 AM
Bailhatch's Avatar
Default Re: what type of size housings should i be lookin for in a turbo (tgreaves)
compressor covers and turbine housings come in different A/Rs so that you can tune between each wheel size. So for each compressor wheel you might have 2 or 3 different sized covers before you jump up to the next biggest wheel with the smallest housing. So it's really a pointless question unless you already know the sizes you want. If anyone says 'oh, well if you have a b18b than you need to get a .60 A/R compressor' just smile and nod.
hope that helps.
Old Apr 8, 2004 | 10:01 AM
tgreaves's Avatar
Default Re: what type of size housings should i be lookin for in a turbo (Bailhatch)
I might have kinda read this the wrong way.. I was assuming he was asking for what size turbo he should use meaning a t28,t3,t4,ect..
I actually would like to learn more about the different trims on turbos.. Is there anywhere on the net that this is documented in more detail..
Kid-jdm-teggy
May 1, 2014 04:48 AM
the.hamburglar
Mar 13, 2008 08:32 PM
zchs21
Jan 23, 2006 10:08 PM
blackeg
Nov 15, 2004 06:05 PM
95TurboLS
Jun 16, 2003 06:12 PM
