very sticky throttle body........... compatiblity????
i have a 92 jdm b16a and my throttle is very sticky...almost every time i give it a Little gas the tb gets stuck..ill be totally off the gas pedal and my vafc will read like 4.3% throttle or whatever i was last at..i tried cleaning it and it didn't help at all so im thinking about just buying another tb and sending it out to the big bore throttle body guy here on h-t to clean it up really good bore it out and set the tps to spec, im just wondering if there are any other throttle bodys that Will fit on my 2nd gen jdm b16a, also what gasket would i use?
thanks-johnny
thanks-johnny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sideout »</TD></TR><TR><TD CLASS="quote">is it reading closed when you first start the car? You might just need to recalibrare the TPS
yes, recalibrating the TPS would get rip of the problem with the VAFC reading 4.3% open with a completely closed throttle but, it wouldn't fix the sticky throttle problem.
what i did was, i took off my friend's throttle body and adjusted the nut on the bottom of the throttle body that acts as a stopper for the throttle plate.
there should be a stud and a locknut below the throttle plate. i adjusted it enough so it wouldn't stick and to not adversely affect the idle. adjust it so, it wouldn't stick and when you put it up against a light, there is no or very little light showing through the edges of the throttle plate.
</TD></TR></TABLE>yes, recalibrating the TPS would get rip of the problem with the VAFC reading 4.3% open with a completely closed throttle but, it wouldn't fix the sticky throttle problem.
when i start it up it reads zero % throttle so i dont think its my tps, also i checked it on my vafc and its reading .45 closed throttle and 4.5 wot(if i rember the numbers correctly)
like i said, the TPS voltage has nothing to do with the sticking throttle body. read my entire post and maybe it'll help you out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">like i said, the TPS voltage has nothing to do with the sticking throttle body. read my entire post and maybe it'll help you out. </TD></TR></TABLE>
so was the plate actually getting stuck on the stud?..sorry man i read it but i wasnt really comprehending it until now
If you pull the intake off you should be able to tell by looking what it is sticking on. If you unhook the cable and it moves fine then you know thats the problem, otherwise you may just have to clean it like the guy said.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">
no it isn't stuck on the stud but, the stud on the bottom of the throttle body regulates how much the plate is actually opened at completely closed throttle. so, if you raise the stud a little and lock it with the lock nut, the plate will rest on the stud
</TD></TR></TABLE>no it isn't stuck on the stud but, the stud on the bottom of the throttle body regulates how much the plate is actually opened at completely closed throttle. so, if you raise the stud a little and lock it with the lock nut, the plate will rest on the stud
alscrx
Nov 18, 2008 04:57 AM
crooked muffler
Jul 29, 2003 07:14 PM
