Where do i add trans fluid at??
Hey guys I have a 94 h22a jdm motor, i was wondering where the hell is the place to add trans fluid to?
I have no idea b/c im very unfimiliar to this motor, If anyone could point it out that would be great thanks.
for help
for help
the easiest way is to fill it at the speed sensor (what i heard)
the other way is the filler hole next to the axle, its a 17mm like the oil drain plug and i think it uses the same crush washer.
Yep, to the left and a little up from the passenger side front axle...Looks like the oil drain plug. Unscrew it and drop a hose w/ a funnel in from above and fill it until it starts to overflow....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 »</TD></TR><TR><TD CLASS="quote">how do you know when its full..... when it starts to overflow... lol?????</TD></TR></TABLE>
Basically... if you use the proper fill hole. 3 quarts should be all you need.
niceprelude
10
Feb 8, 2009 04:20 PM
4doorRS5spd
Sep 2, 2001 08:40 PM
