clutch cylinder
Old Apr 7, 2004 | 05:42 PM
FK00GSR's Avatar
Default clutch cylinder
after i installed my clutch master cylinder my clutch grabbed really low to the floor. Is that normal or did i do something wrong?
Old Apr 7, 2004 | 06:18 PM
FK00GSR's Avatar
Default Re: clutch cylinder (FK00GSR)
just a quick answer will do.
Old Apr 11, 2004 | 11:47 AM
FK00GSR's Avatar
are you supposed to adjust the clutch pedal after installing a new clutch master cylinder?
Old Apr 11, 2004 | 11:57 AM
cougar10ag's Avatar
you cna adjust it..
http://www.redpepperracing.com...2/aad
Old Apr 11, 2004 | 12:00 PM
FK00GSR's Avatar
Default Re: (cougar10ag)
i know how to adjust it but I just wanted to know whether you need to adjust it when installing a new clutch master cylinder or is it already adjusted at the right height/level for you?
Old Apr 11, 2004 | 12:02 PM
Kendall's Avatar
You should readjust it to factory specs after any major clutch work.
Old Apr 11, 2004 | 12:05 PM
FK00GSR's Avatar
Default Re: (Kendall)
is a cmc replacement a major clutch work?
How about if I never did any other work to the clutch just replaced the cmc, is there any adjusted involved or is it literally tightened the 2 bolts insert cotter pin, attach hose to the reservoir and rebleed system?
Old Apr 11, 2004 | 12:07 PM
cougar10ag's Avatar
major clutch work are you serious? you just replaced the master cyl.. i would say thats major... just adjust it.
Old Apr 11, 2004 | 12:08 PM
dougw101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cougar10ag &raquo;</TD></TR><TR><TD CLASS="quote">major clutch work are you serious? you just replaced the master cyl.. i would say thats major... just adjust it.</TD></TR></TABLE>
Old Apr 11, 2004 | 12:12 PM
FK00GSR's Avatar
Default Re: (dougw101)
thanks guys will do, also what is the best cmc i hear the prelude and accord are slightly better or is this not true. should i just get an oem integra one?
Old Apr 11, 2004 | 12:17 PM
cougar10ag's Avatar
integra one.. it's perfectly fine.. theres not better or worse master cyl.. it was made for the car you drive so get it.. it's like those brake master cyl braces and ****.. that supossedly increase brake feel by keeping the master cyl from moving. it's all BS to get more money.. you know that most parts on the cars all the winners are OEM.
ohsnapzafingcu
May 16, 2011 04:30 PM
krysted9354
Dec 30, 2008 09:19 PM
b16a4
Nov 18, 2006 11:04 AM
s1ngle
13
Sep 21, 2005 12:01 PM
FLCivic
Jun 30, 2004 03:48 PM
