Subwoofer won't work
Old Apr 7, 2004 | 05:26 PM
SlippylesKB's Avatar
Default Subwoofer won't work
Well today I went out and bought an Alpine Type S 10" sub and an Alpine MRD M300 amp. The Amp has power, but the subwoofer won't work. Any Ideas? It's a Dual Voice Coil subwoofer if that helps.
Old Apr 7, 2004 | 06:17 PM
ATF Kuk's Avatar
Default Re: Subwoofer won't work (SlippylesKB)
did u connect rca's? if so, take the sub out and see if its connected to the terminal cup
Old Apr 7, 2004 | 06:27 PM
Default Re: Subwoofer won't work (ATF Kuk)
Yea, the RCA's are plugged in. I'm not positive if I've wired up the sub correctly... Also, I've been searching around and I"ve just found out that the ground wire has to be an 8 gauge but I've got a 10 gauge. Think that has to be the problem?
BTW: The new South Park is HILARIOUS!
Old Apr 7, 2004 | 07:20 PM
Full Race A6's Avatar
I think youre grounds fine that size
Old Apr 7, 2004 | 09:40 PM
screen_name's Avatar
did u try swapping the sub? and hooking up another one?
Old Apr 8, 2004 | 05:24 AM
Default Re: (Tegra562)
don't have another one to plug in
Old Apr 8, 2004 | 05:28 AM
GSRrR's Avatar
Default Re: (SlippylesKB)
how did you wire it?
here is a good read.
http://www.jlaudio.com/tutorials/wiring/index.html
Old Apr 8, 2004 | 05:29 AM
project yak's Avatar
how did u wire it up? you said u weren't sure if u did it right?
Old Apr 8, 2004 | 05:31 AM
Default Re: (GSRrR)
ha ha GSR we posted same question at the same time u beat me by a couple seconds
Old Apr 8, 2004 | 07:25 AM
AndyGCT's Avatar
you have to make a circular loop with the wiring on a DVC sub...
Lets say on one subwoofer:
SIDE A has connectors - +
SIDE B has connectors + -
The box has one connector - +
With one speaker wire connect Side A + directly to Side B -
Then one speaker wire from Side A - to the box connector -
Then one speaker wire from Side B + to the box connector +
Now repeat the process for the second sub...
If youre not too good with + and - the positive is always RED and the negitive is BLACK
You just looped it....Thats one of the proper and EASIEST ways to do it...
Old Apr 8, 2004 | 08:38 AM
Default Re: Subwoofer won't work (AndyGCT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyGCT &raquo;</TD></TR><TR><TD CLASS="quote">you have to make a circular loop with the wiring on a DVC sub...
I've only got one sub though... so would I have to wire up the single sub the same way??
Old Apr 8, 2004 | 08:49 AM
TnTWRX's Avatar
Check this link out for wiring options
http://www.rockfordfosgate.com....y=11
Old Apr 8, 2004 | 10:49 AM
AndyGCT's Avatar
yeah thats directions for doing them one at a time. You just repeat it if you have more than one sub. Because one sub should have two sets of connections, One set is Side A and the other set is Side B in the description i gave you...
That link above me to the rockford site, check out wiring Diagram 2, thats what i was explaining, but usually the + & - are opposite of each other to make it easier...
Just take your time and check your connections... You'll be fine. Just post up or PM me if you have anymore questions
Old Apr 8, 2004 | 04:13 PM
Got it to work, thanks guys for the help.
Old Apr 8, 2004 | 04:23 PM
TnTWRX's Avatar
No problem
Old Apr 12, 2004 | 07:28 AM
AndyGCT's Avatar
np congrats on the install!! Fun aint it lol
ODbuilt
Audio / Security / Video
Apr 27, 2014 11:43 PM
zsudz922
21
Oct 30, 2008 12:16 PM
ws350z
Sep 26, 2008 09:35 PM
A.E Motoring
15
Nov 1, 2005 09:53 PM
imlachg1
Mar 24, 2004 03:25 PM
