Amp for 2 300w subs and sub box mounting question
basically I'm looking for any suggestions for an amp to power 2 300w Pioneer subs...I'm not the best when it comes to audio, so would I be looking for something like a 600w 2channel amp, right? looking for a price range of $150-175 if possible...any suggestions
also as far as mounting, I'm using L-brackets to attach the sub box to the trunk board, are there any type of quick release bolts/fastners(almost like a hood pin) that I could use which would allow the box to be pulled out pretty easy? Thanks for any input, this is in a 99Si if that matters
What is the exact model number for the subs?
And for the easy removal, I would set the box in place and then secure the L brackets down around it, but no to the box. When big boxes move, they slide, and this way they won't slide. Then when you need to remove the box, you just lift it out.
4doorex
Audio / Security / Video
Oct 24, 2003 10:57 PM
