b16 first gen or b16a2 99-00 SI UDSM motor..
Old Apr 7, 2004 | 03:40 AM
phatboy's Avatar
Default b16 first gen or b16a2 99-00 SI UDSM motor..
Whats the difference in the blocks...i have a jdm block right now and a b16a2 block any difference? aslo whick motor has more horsepower? let me know thanx
Old Apr 7, 2004 | 02:23 PM
phatboy's Avatar
Default Re: b16 first gen or b16a2 99-00 SI UDSM motor.. (phatboy)
BUMP
Old Apr 7, 2004 | 05:21 PM
d00kee's Avatar
b16a1
Mileage: 40,000-55,000 miles
1595cc (DOHC VTEC)
Horsepower: 158hp@7600rpm
Torque: 112lbs-ft@7000rpm
Compression: 10.2:1
Bore: 81mm
Stroke: 77.4mm
OBD: 0
Redline: 8200rpm
b16a2
Mileage: 35,000-45,000 miles
1595cc (DOHC VTEC)
Horsepower: 168hp@7800rpm
Torque: 116lbs-ft@5200rpm
Compression: 10.4:1
Bore: 81mm
Stroke: 77.4mm
OBD: 1
Redline: 8200rpm
hope that helps
Old Apr 7, 2004 | 05:41 PM
jdmsijdm's Avatar
actually the b16a usdm si motor only makes 160 hp, 111tq, and the red line is 8k and the fuel cut is 8200. Also the compression is 10.2:1
the specs he listed there for the b16a2 i believe are for the second gen jdm b16, not the usdm b16
Old Apr 7, 2004 | 05:48 PM
Heylookits shawn's Avatar
Default Re: (jdmsijdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d00kee &raquo;</TD></TR><TR><TD CLASS="quote">b16a1
1595cc (DOHC VTEC)
Compression: 10.2:1
Bore: 81mm
Stroke: 77.4mm
OBD: 0
Redline: 8200rpm
b16a2
1595cc (DOHC VTEC)
Compression: 10.4:1
Bore: 81mm
Stroke: 77.4mm
OBD: 1
Redline: 8200rpm
hope that helps
other way around
jdm b16a1 has 10.4 cr and around 170 hp
b16a2 has 10.2 cr with around 160
Old Apr 7, 2004 | 06:29 PM
mmuller's Avatar
Mad Scientist
Default Re: (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">
other way around
b16a2 has 10.2 cr with around 160</TD></TR></TABLE>
hehe no.
1st gen b16=pr3 pistons 10.2 comp.
2nd gen jdm b16= p30 pistons 10.4 comp.(170hp)
all usdm b16's have pr3 pistons and 10.2 comp.
Old Apr 7, 2004 | 07:14 PM
d00kee's Avatar
i just pulled that off of "www.totaljdm.com", but im not gonna argue.
Old Apr 7, 2004 | 07:16 PM
d00kee's Avatar
Default Re: (d00kee)
yeah i saw he was looking for usdm motors after i posted but id rather go jdm than usdm so i mighta helped him out a lil and steered him in the right path or just waisted space
Old Apr 7, 2004 | 07:31 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatboy &raquo;</TD></TR><TR><TD CLASS="quote">Whats the difference in the blocks...</TD></TR></TABLE>
The blocks are identical. Both are PR3 blocks.
Old Apr 7, 2004 | 07:40 PM
phatboy's Avatar
Default Re: b16 first gen or b16a2 99-00 SI UDSM motor.. (Kendall)
why does the jdm one have less horsepower than the usdm 99-00 motor? this is the first gen motor
Old Apr 7, 2004 | 07:43 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatboy &raquo;</TD></TR><TR><TD CLASS="quote">why does the jdm one have less horsepower than the usdm 99-00 motor? this is the first gen motor</TD></TR></TABLE>
It doesn't. They both have the same internal components and produce the same output. The JDM second gen B16A's are the ones with increased horsepower over the others.
Old Apr 7, 2004 | 09:39 PM
mmuller's Avatar
Mad Scientist
actually differences in hp wise between 1st gen b16 and all usdm b16 is the cams.
mayor part why 1st gen b16's have less power is the cams
Old Apr 8, 2004 | 05:54 AM
obd1gsr's Avatar
Default Re: b16 first gen or b16a2 99-00 SI UDSM motor.. (mmuller)
what about a jdm b16a? how much do those put out?
dachinkrac3r
Mar 1, 2006 08:38 PM
mmmsushi
13
Sep 17, 2005 11:08 AM
Methane2k2
Mar 5, 2005 11:37 AM
hectorg4444
Sep 9, 2004 03:09 PM
dailygirl
25
Jun 21, 2004 08:56 AM
