where can i get a camber kit for a 88 crx hf lowered atleast 2"
where and about how much am i looking at?? my car has bad camber problem and its not align. my front right tire is pretty worn out cause of it.. about to get some tokikos illuminas and might aswell get some camber kit..
If your going to go with ingalls you are looking to spend good $$$, you can also get an a full set on ebay for less than $100.00, I could not tell you how good they are. Remember that after you install them you will also need an alignment.
You might be able to ghetto rig the rear with just washers, someone please confirm. Well here are some links, good luck.
http://www.ebay.com
http://www.racerwheel.com/eib-584580k.html
http://www.seffects.com/catalo...nsion
http://www.ebay.com
