crx camber kit problems
Old Jul 24, 2004 | 10:13 PM
AKEFVTEC's Avatar
Default crx camber kit problems
i gotta 88 crx with H&R 1 inch drop oe sport springs and koni yellows. I installed a set of Ingalls adjustable camber kit for the front tires myself a bout 4 months ago because i didnt want any premature tire wear due to negative camber. but now i have camber wear. could the tire wear be due to me not getting the car to an alignment shop to adjust toe or caster after i installed the kit???
Old Jul 25, 2004 | 06:33 AM
spaceman's Avatar
Default Re: crx camber kit problems (AKEFVTEC)
probably
Old Jul 25, 2004 | 01:04 PM
kur0ryu's Avatar
Default Re: crx camber kit problems (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">probably</TD></TR></TABLE>
I have an ingalls copy kit, and even with fully adjusting and taking it to a shop for alignment, they still weren't able to get it fully corrected.
Old Jul 25, 2004 | 09:52 PM
AKEFVTEC's Avatar
Default Re: crx camber kit problems (kur0ryu)
im gonna try the SPC ball joint style camber adj kit. but i wonder why it says its for the 89-91 civic/crx. why isnt it for the 88 models?
Old Jul 25, 2004 | 11:36 PM
spaceman's Avatar
i dunno but i would like for web sites to clarify why some of them say there parts are for 89-91 and not 88..if they dont make stuff for 88 then they should,cuz thats what i got..hehe
Old Jul 26, 2004 | 01:10 PM
kur0ryu's Avatar
I thought that the only difference was the LCA's on the 88's were JDM/ITR style... I didn't think that had anything to do with it...
Old Jul 26, 2004 | 04:17 PM
Xsi's Avatar
Xsi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AKEFVTEC &raquo;</TD></TR><TR><TD CLASS="quote"> could the tire wear be due to me not getting the car to an alignment shop to adjust toe or caster after i installed the kit???</TD></TR></TABLE>
Yes, your toe settings are most likely killing your tyres. With only a 1 inch drop you could probably have gotten by with just an alignment to get your toe in spec and no camber kit.
Old Jul 31, 2004 | 12:35 PM
AKEFVTEC's Avatar
i called SPC and they told me that the first half of 1988 while HONDA was manufacturing the CRX, they gave it ball joints that were welded into the upper front control arm. before you go and get the SPC or Ingalls adj ball joint camber kit they offer check to see if yours is welded in. I just checked mine and they are.
Arbiter
Suspension & Brakes
Nov 13, 2007 03:32 PM
JustinHoMi
Suspension & Brakes
Feb 21, 2006 08:27 AM
B18C5er
Suspension & Brakes
20
Nov 18, 2005 07:44 AM
vtec_head
Aug 18, 2004 04:59 PM
AKEFVTEC
Jul 25, 2004 10:07 PM
