problems following distributer installation
Old Oct 25, 2001 | 05:20 PM
John's Avatar
New User
Default problems following distributer installation
I installed a replacement Hitachi distributer this evening on my F22B1... However, now my powerband is all screwey, no low end power whatsoever... I'm assuming its my ignition timing... so how do I set it back to the OEM ignition timing setting (aside from my cam timing setting)? do i have to use a timing gun? help!
Old Oct 25, 2001 | 05:40 PM
madslackin's Avatar
Default Re: problems following distributer installation (DunReit)
Yes, use a timing gun and set it to stock ignition timing. Do a search for how to do this, or if you have a friend with a timing gun, he/she can probably show you how to use it.
Justin
Old Oct 25, 2001 | 06:01 PM
John's Avatar
New User
Default Re: problems following distributer installation (madslackin)
i think i rectified the problem by loosing the distributer bolts and rotating it... my ignition timing was way too retarded!!!
Old Oct 25, 2001 | 10:49 PM
earl's Avatar
You STILL need to set it with a timing light to be sure. Don't want no stinkin detonation.
eg grom
Jun 25, 2009 09:27 PM
civic j
Aug 17, 2007 08:10 AM
mortificationrock
Jul 10, 2007 04:26 PM
infinate bound
Mar 18, 2004 10:35 AM
John
Oct 26, 2001 12:54 PM
