Denso Iridium Spark Plugs
Zero gains and they're pricy. Irridium is a worse conductor than either copper or platinum it just lasts longer in the engine environment. They are suited much better for use in high boost applications.
Gabe
Gabe
I'm guessing by high boost applications, you mean any form of forced induction? I just checked out a website that dynoed a 98 SH that already had a 75 shot of nitrous, AEM Pulleys, AEM CAI, and a Tanabe Exhaust. Gave about a 6 hp gain.
http://www.bottlefedracing.com/image...a_shl-dyno.jpg
Gabe
Gabe
Are you sure? I have always heard that the advantage to iridium plugs is that they have the longevity of platinum AND conduct better....but copper still conducts the best.
I have to agree with Corey, I use NGK coppers. They're cheap and dependable.
Gabe
I have bosch +4 they are between. Good cheap ones not expensive and a different design. Not good for Nitrous apps. tho. they are too hot oh well.
Denso are too priecy for me.
Put down the densos and walk away very fast! I had them in my car for a couple of months. The car started to run like ****. I yanked the plugs, and the electrodes were eaten to ****. Waste of $40+. Now I just have some good ol'e NGK in the H22.
Subject: Denso Iridium Race plugs VS Bosch Platinum #4227
The Denso sells for $60+ a set and lasts a long long time.
The Bosch #4227 platinum sells for about $8 a set and lasts a long, long time.
The blue line is the Denso. Look how close it is!! What a race!
Take it for what it is...same car, back to back runs...several runs on each plug...and its NOT the best run vs. the worst run...its an average...and
consistently, the Denso showed SLIGHT improvement. As in SLIGHT.
Thanks to Jeff from importreview.com (importbuilders.com)
Note: I am more in favor of NGK - all the way!
Drew Peacock
Oct 21, 2003 10:25 PM
Best performance
