Run a OBD1 Dizzy with a OBD0 PR3 ECU??
you can't run an obd-1 distributor with an obd-0 ecu. the trigger wheel in the obd-0 distributor has 16 teeth while the trigger in the obd-1 distributor has 24 teeth. The ecu will not be able to read the distributor properly and will not run the engine. you have to switch them in pairs. obd-0 ecu and obd-0 distributor, or obd-1 ecu and obd-1 distributor
Well That is funny then I either got ripped off
which ain't happening it is my buddy's dizzy off a 92-95 civic
so then what is my thing then
can u guys figure that then
all we did was switch the clips and there I got a obd1 with better sensors
In my experience there is no way you are using a distributor with a 24 tooth trigger wheel in combination with an ecu that is designed to read a 16 tooth trigger wheeland no other mods. fuel injection doesn't work like that. this is the reason that when switching to an obd-1 ecu in our obd-0 cars that one of the other parts that needs to be replaced is the distributor. the ecu counts the teeth as they pass the sensor to know where the crank is, that way it can open injectors at the right time and send spark at the right time. are you sure you are running an obd-0 ecu?
I run an aem ems in my crx and use an obd-2 distributor that has a 24 tooth wheel. I have the option to run the older distributor but it requires setting changes so that the ecu can correctly interpret crank position. I have not come across any honda ecu that changes itself in this way.
hey man u really got me thinking now
maybe I don't got it right
but I am running a PR3 mugen chip
and it is or was a grey clip
and the injectors I got are RC 310 cc injectors
wow I need to figure this out
i am pretty sure that there is an obd-1 pr3, but its not very common.
obd-1 ecu plugs look like this
obd-0 ecu plugs look like this
the ecu model can be read from the sticker on the side so long as noone has moved the guts from another ecu into the current ecu case. Not common but has been done.
Modified by racerxadam at 1:18 AM 4/6/2004
