Throwout bearing or Inputshaft bearing?
Old Apr 5, 2004 | 02:08 PM
Ditdogs's Avatar
Default Throwout bearing or Inputshaft bearing?
hey guys, im haveing abit of a tranny prob. my trans and/or clutch is makeing this spinning noise when i disengage (press down on the) clutch. It is also ruff to put the car into gear. To me it sounds like the throwout bearing problem, but i did some searching and i am getting mixed answers. any help would be great.
Also sometimes i can not put the car into gear when i turn it on, and need to turn my car on and off a few times before i can put it into reverse or 1st.
GSR tranny by the way.
thnx in advance
Old Apr 5, 2004 | 03:16 PM
tilt's Avatar
Default Re: Throwout bearing or Inputshaft bearing? (Ditdogs)
sounds like to bearing. input shaft bearing makes noise when you are in gear or even in neutral but clutch is out. if you put the clutch in, the input shaft stops spinning... make sense?
as for getting locked out of gears... you may need to bleed the hydraulics, or something inside your clutch disc or plate blew up - pretty common if you have stock clutch with around 100k
Old Apr 5, 2004 | 05:24 PM
brisk's Avatar
hmm thats funny cuz it makes noise when you press on the clutch. my car makes noise when its seting in neutral with my foot off the pedal. And i think its the throwout bearing in my car. could be the release bearing in yours
Old Apr 6, 2004 | 08:37 AM
Ditdogs's Avatar
Default Re: Throwout bearing or Inputshaft bearing? (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">as for getting locked out of gears... you may need to bleed the hydraulics, or something inside your clutch disc or plate blew up - pretty common if you have stock clutch with around 100k</TD></TR></TABLE>
i have a exedy stage 2 clutch, had it for about a year now. hrmm... maybe ill get a new a ATC clutch sence i am going to be down there anyhow...
Old Apr 6, 2004 | 05:24 PM
Ditdogs's Avatar
bump
Old Apr 6, 2004 | 06:00 PM
doublejz's Avatar
Default Re: Throwout bearing or Inputshaft bearing? (brisk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brisk &raquo;</TD></TR><TR><TD CLASS="quote">hmm thats funny cuz it makes noise when you press on the clutch. my car makes noise when its seting in neutral with my foot off the pedal. And i think its the throwout bearing in my car. could be the release bearing in yours</TD></TR></TABLE>
first off release bearing = throwout bearing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ditdogs &raquo;</TD></TR><TR><TD CLASS="quote">my trans and/or clutch is makeing this spinning noise when i disengage (press down on the) clutch. To me it sounds like the throwout bearing problem</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ditdogs &raquo;</TD></TR><TR><TD CLASS="quote">Also sometimes i can not put the car into gear when i turn it on, and need to turn my car on and off a few times before i can put it into reverse or 1st. </TD></TR></TABLE>
its possible the clutch is about gone, does it slip if you pop the clutch when shifting? it also may be your master/slave cyclinder.
Old Apr 7, 2004 | 05:42 PM
Ditdogs's Avatar
Default Re: Throwout bearing or Inputshaft bearing? (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">its possible the clutch is about gone, does it slip if you pop the clutch when shifting? it also may be your master/slave cyclinder.</TD></TR></TABLE>
hrmm... if my master/slave cyclinder is shot what needs to be done to fix it? new trans all together? i was thinking i am getting the not being able to put it into gear problem b/c i might have faqed the teeth on the plate...
Old Apr 7, 2004 | 06:30 PM
doublejz's Avatar
if you master or slave it bad you can just go to like autozone and get another. Not pricey at all. I would have some press the clutch pedal and see if the slave cylinder is extending/traveling far enough to really be doing anything with your clutch. If its barely moving, i would replace the slave first since its like $20. Your petty isn't soft, and really easy to push is it? if it is you may have air in the line
Old Apr 8, 2004 | 01:49 PM
Ditdogs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">if you master or slave it bad you can just go to like autozone and get another. Not pricey at all. I would have some press the clutch pedal and see if the slave cylinder is extending/traveling far enough to really be doing anything with your clutch. If its barely moving, i would replace the slave first since its like $20. Your petty isn't soft, and really easy to push is it? if it is you may have air in the line</TD></TR></TABLE>
nah the clutch pedal feels fine, i have the exedy stage 2 kit (disk, p plate, throwout bearing) , and the clutch feels fine. i was going to drop the trans today but it is raining out, guess it will have to wait till friday. ill keep you posted.
i ordered a 12.5 lbs flywheel and stage 2 exedy kit again. even though this exedy craped out on me, i still think exedy is one of the best out there... just my thoughts... we will see how it goes.
Old Apr 16, 2004 | 01:16 AM
Ditdogs's Avatar
so it was BEAUTIFUL! out today so i decided to drop my trans and figure out what the **** was going on. I drop the trans, took out my clutch/flywheel to find that my spring centered exedy organic disc was.... F.U.B.A.R.D... 2 spring side walls where basically broken off causing the spring to move in and out of the little socket. I put in my new exedy stage 2 racing disc w/ new pressure plate, and throwout bearing (EXTRA!!!! grease). Also i decided to change the flywheel to the exedy 10lb.
All and all the whole job took me about 2 hours 1/2. Car is running smooth as all hell right now and the problem seems to be fixed. all that is left for me to do is brake the bad boy in.
Old Apr 17, 2004 | 10:57 PM
turbohondask's Avatar
that is a common problem with hondas i remeber that one of the springs fell out on me before and i could barely shift into any gears and it made a horrible clicking nosie
04civicex84
Honda Civic (2001 - 2005)
Nov 13, 2008 02:44 PM
Baron55
Dec 19, 2006 06:25 PM
EM1_
19
Jan 23, 2006 09:00 PM
pa2play
Jul 28, 2005 09:42 AM
Takeoff
Dec 11, 2003 06:45 PM
