Door lock problems
Has anyone ever had problems with their door locks on Gen 3 Integras? Today, I tried locking my doors, but, the driver side won't lock. It seems like it gets stuck. The passenger side locks though. I sprayed some WD-40 into the lock hole, and it works, but, not everytime. Anyone else had this problem? What did you do to fix it?
i had the same problem but i don't know how i fixed it.. i took off the door panel didn't see anything wrong, so i put it back together and it's working fine. it's been ok for about 2 months.
You have to hold the inside door handle in the open position when locking the driver's side. I guess it's some sort of security feature so you can open the door in case you forget your keys.
HTH.
HTH.
I had the problem about two months ago, took the door apart, and found nothing. My dad sprayed WD-40 into the lock, and it worked fine. Now, today, its giving me problems again. I sprayed it with wd-40 again, and hopefully its working ok again.
I've never heard of holding the handle in the open position, but, I'll try it.
had the same problem.. I thought it was my alarm.. but i guess something got caught. Happened one more time after that and its been fine since
J.WOLFE~v1.0
Dec 23, 2010 04:23 PM
alacard
16
Jan 25, 2007 09:55 AM
