taking out axles?
Old Apr 5, 2004 | 12:19 PM
hellogoodbye's Avatar
Default taking out axles?
i ran into a problem while replacing my axles. my passenger side snapped off. does anyone know how to take the axles out of the tranny?
Old Apr 5, 2004 | 12:26 PM
SleepyEG's Avatar
Default Re: taking out axles? (tekneek)
pull
Old Apr 5, 2004 | 12:34 PM
civickiller's Avatar
Default Re: taking out axles? (SleepyEG)
pound it out from the drivers side
Old Apr 5, 2004 | 12:44 PM
SleepyEG's Avatar
Default Re: taking out axles? (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">pound it out from the drivers side</TD></TR></TABLE>
care to explain how to safely do this? I wouldn't put anything through my tranny and hit it with a hammer, but that's just me. If you've got the axle out of the hub, there is no reason you shouldn't be able to just pull it out of the tranny
Old Apr 5, 2004 | 01:00 PM
SAVIOVEGA's Avatar
You should just be able to pop it out with a large srewdriver or prybar. If not, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">pound it out from the drivers side</TD></TR></TABLE>
Use a long srewdriver to tap it out from the driver's side.
Old Apr 5, 2004 | 02:35 PM
Default Re: taking out axles? (SAVIOVEGA)
thats what i was saying. get a long screw driver and just tap it out, it should come out easy, if not hit alittle harder. i didnt litterally mean get a big hammer and jsut start beating the tranny till it comes out
Old Apr 5, 2004 | 04:11 PM
thad
Guest
Posts: n/a
got LSD?
no ... then youve got a pin through the diff that'll get in the way. maybethey just put that there so people wouldn't try to hammer the axels out,
just put a large flathead between the tranny and the axle and pry. carful not to gouge the seal.
95EXcivicsleeper
Aug 22, 2007 01:04 PM
spoonracer84eg
13
Oct 28, 2006 11:58 AM
hammerdgolfer
16
Jun 24, 2004 06:33 PM
drewbie
Jun 6, 2004 10:04 PM
Rev-Olution
Sep 21, 2003 05:39 PM
