Swaybar question
Old Apr 5, 2004 | 10:31 AM
JDM R's Avatar
Default Swaybar question
Just wondering... I have a 97 hatch and was thinkin about installing an Si rear swaybar. Should i worry about my subframe tearing out? At what diameter swaybar should i worry about subframe tearout? Thanks
Old Apr 5, 2004 | 12:45 PM
Katman's Avatar
Default Re: Swaybar question (JDMar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMar &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering... I have a 97 hatch and was thinkin about installing an Si rear swaybar. Should i worry about my subframe tearing out? At what diameter swaybar should i worry about subframe tearout? Thanks</TD></TR></TABLE>
you should be fine with an Si coupe rr swaybar. Its a small diamter swaybar anyways (13mm I believe).
The only time you need to worry about swaybar ripping your subframe is when you run a thicker bar (type-R size-22mm or bigger) + run a soft spring rate/suspension setup.
Old Apr 5, 2004 | 06:10 PM
JDM R's Avatar
Default Re: Swaybar question (Katman)
Thanks for the info!
mkselecta
May 21, 2007 11:47 PM
Black R
Oct 19, 2006 06:08 PM
EL Vap133
15
Apr 14, 2005 05:26 PM
C M S
Jul 20, 2004 05:57 PM
^Sammy]!.
Feb 9, 2004 07:39 PM
