Honda LSD question
Old Apr 5, 2004 | 10:19 AM
OEM_Spec's Avatar
Default Honda LSD question
I was wondering if you guys know who makes Honda's LSD? Someone told Kaaz. But I doubt that highly. And I also highly doubt that any Honda LSD uses clutch packs. I thought it was all helical/torsen/gear with some exceptions of viscous.*spelling* Can anyone clearify so I can prove this person wrong...or myself perhaps?
Thanks
Old Apr 5, 2004 | 10:40 AM
spaceman's Avatar
Default Re: Honda LSD question (OEM_Spec)
good question..i was wondering how hard it would be to put an oem lsd into my s1 tranny and if its possible
Old Apr 5, 2004 | 11:34 AM
Kal's Avatar
Kal
Default Re: Honda LSD question (spaceman)
i wanna know also... don't think it's kaaz at all
Old Apr 5, 2004 | 12:49 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEM_Spec &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if you guys know who makes Honda's LSD? Someone told Kaaz. But I doubt that highly. And I also highly doubt that any Honda LSD uses clutch packs. I thought it was all helical/torsen/gear with some exceptions of viscous.*spelling* Can anyone clearify so I can prove this person wrong...or myself perhaps?
Thanks</TD></TR></TABLE>
I believe Honda (of Japan) makes their own LSD's in their tranny department. I could be wrong though.
The older Y1 89-91 B16 cable transmissions come equipped with a clutch-type LSD whereas the newer hydro (92+) tranny's use gear type LSD's. Type-R LSD's use the torsen-helical LSD. If i'm not mistaken, I *think* all of the honda gear type LSD's are helical.
side note:
There is no factory Honda LSD that will work in an S1 or J1 tranny. You'd have to go aftermarket LSD for the S1/J1 tranny's.
Old Apr 5, 2004 | 03:11 PM
mugenek007's Avatar
Default Re: Honda LSD question (Katman)
what about a 99 ls tranny. could i use the hond LSD on this??
Old Apr 5, 2004 | 04:21 PM
OEM_Spec's Avatar
So as of now typically speaking, all cars that are equiped with LSD these days from Honda is torsen helical type?...And should be no where near clutch packs? I really didn't think they would use clutch packs now...I thought maintenance would be an issue...and thats totally not Hondas' styles at all!
Old Apr 5, 2004 | 04:33 PM
spaceman's Avatar
ya i would go for the gear type,i wouldnt wanna have to replace the lsd clutch..whats a good lsd for not much money that i could put into my s1 tranny?..im looking for a daily driver/road race and reliablility lsd
Old Apr 5, 2004 | 07:15 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OEM_Spec &raquo;</TD></TR><TR><TD CLASS="quote">So as of now typically speaking, all cars that are equiped with LSD these days from Honda is torsen helical type?...And should be no where near clutch packs? I really didn't think they would use clutch packs now...I thought maintenance would be an issue...and thats totally not Hondas' styles at all! </TD></TR></TABLE>
yeah, all hydro tranny's equipped w/an OEM LSD are gear type.
Old Apr 5, 2004 | 07:16 PM
Katman's Avatar
Default Re: Honda LSD question (mugenek007)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenek007 &raquo;</TD></TR><TR><TD CLASS="quote">what about a 99 ls tranny. could i use the hond LSD on this??</TD></TR></TABLE>
yes, you can drop in any JDM OEM B18C/B18C-R/or CTR LSD into your LS tranny. But you cannot drop a hydro B16A LSD in unless you use the B16A ring gear because of the smaller diameter the ring gear & LSD have as a whole.
Old Apr 5, 2004 | 08:48 PM
mugenek007's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
yes, you can drop in any JDM OEM B18C/B18C-R/or CTR LSD into your LS tranny. But you cannot drop a hydro B16A LSD in unless you use the B16A ring gear because of the smaller diameter the ring gear & LSD have as a whole.</TD></TR></TABLE>
which one would be a better LSD out of the 3 and about how much would one of those cost?
Old Apr 6, 2004 | 07:37 AM
spaceman's Avatar
is there a jdm oem lsd that would work in a jdm s1 tranny?
Old Apr 6, 2004 | 08:11 AM
FwdCivicHatch's Avatar
If you could find the Honda LSD anywhere, it probably still be cheaper to buy a Quiafe.
Old Apr 6, 2004 | 08:18 AM
spaceman's Avatar
Default Re: Honda LSD question (FwdCivicHatch)
thanks for the info
Old Apr 6, 2004 | 10:58 AM
Katman's Avatar
which one would be a better LSD out of the 3 and about how much would one of those cost?</TD></TR></TABLE>
Either CTR or ITR LSD (same design/make up). You can find them used for about $400-500 on the net.
Aodhan
Oct 8, 2007 09:35 AM
clemsoncb7
Apr 2, 2007 07:46 AM
GO-FIGHT-KILL
Oct 8, 2005 08:25 PM
zipsonic
10
Mar 30, 2004 06:18 PM
HuskerHybrid
Dec 21, 2002 12:48 PM
