What is a water pump for?
Old Oct 25, 2001 | 01:33 PM
Fooman's Avatar
Default What is a water pump for?
Some of the members said that the water pump needs replacement around 60k-90k miles. I don't even have a clue on what it is. Anyone care to share some knowledge?
Also, can you hear when the timing belt is going bad? Or is it one of those belts you're better off replacing BEFORE something happens.
Old Oct 25, 2001 | 01:47 PM
MachAF's Avatar
Default Re: What is a water pump for? (Fooman)
It moves the coolant between engine and radiator.
http://www.howstuffworks.com/cooling-system3.htm
Old Oct 25, 2001 | 02:00 PM
96IntegraLS4DR's Avatar
YES
It IS one of those belts you're better off replacing BEFORE something happens.
Old Oct 25, 2001 | 02:25 PM
P73 DA9's Avatar
New User
Default Re: What is a water pump for? (96IntegraLS4DR)
A water pump is used for the pumping of water.
Sorry I had to say it . I thought it was 90k miles to replace timing belt, I'm not sure about water pump. Get some cam gears while you are at it, that will push you to have it done sooner! hehe
Old Oct 25, 2001 | 02:47 PM
immortal's Avatar
Banned
its not a belt
turq93t
10
May 16, 2005 06:00 PM
Raskal
Jan 27, 2005 07:01 AM
snoop_bealybob
Mar 26, 2003 06:04 PM
wonny
Dec 7, 2002 05:45 AM
Volcom
Jan 23, 2002 10:31 AM
