fuel line size with stock pump
Old Apr 4, 2004 | 10:45 PM
civickiller's Avatar
Default fuel line size with stock pump
ok i ripped my fuel line and i was thinking about upgrading to bigger lines because of future plans. now i was wondering how big i could go before my stock fuel pump wouldnt be able to flow enough ? like 6an or 8an ? and also how much hp could i support with the new line ?
Old Apr 5, 2004 | 02:36 PM
Default Re: fuel line size with stock pump (civickiller)
no one knows ?
Old Apr 5, 2004 | 05:15 PM
S-Hall's Avatar
Well in the new Dsport magazine there was a black civic that made 680+ with factory fuel line. -6an on a intank walbro 255lph would be fine.
Old Apr 5, 2004 | 11:30 PM
Default Re: fuel line size with stock pump (S-Hall)
thanks for the info
what size can i go on my fuel line, before its too big for my stock pump ?
Old Apr 6, 2004 | 04:53 AM
JimBlake's Avatar
Your pump & FPR control flow & pressure. Not the size of the line. If you put in a line that's too small it might limit flow, but if the line's too big it's merely a waste.
Old Apr 6, 2004 | 11:02 AM
Default Re: fuel line size with stock pump (JimBlake)
at some point the line will get too big and the fuel pump wont be able to pressurize it enough. for example, a garden hose, now you turn on a small hose and you get good pressure coming out, put on a really big hose and you dont really get any pressure coming out.
Old Apr 7, 2004 | 09:25 AM
oh yeah, this is for the hard line the one that runs through the car
Old Apr 7, 2004 | 06:31 PM
anyone know how much stock pump flows ?
Old Apr 8, 2004 | 11:09 AM
selude's Avatar
3/8 fuel line is used on every car made
Old Apr 9, 2004 | 04:18 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">at some point the line will get too big and the fuel pump wont be able to pressurize it enough. for example, a garden hose, now you turn on a small hose and you get good pressure coming out, put on a really big hose and you dont really get any pressure coming out.</TD></TR></TABLE>Pressure & flow rate & velocity are 3 different things. Lemme know after you pass a couple fluid mechanics courses.
danedoremus
Welding / Fabrication
21
Nov 7, 2011 11:58 AM
airwalk07143
Jun 10, 2010 06:46 PM
JLHDOHC
Apr 30, 2006 04:18 PM
1QwIkEf
Jan 28, 2006 05:05 PM
paulzy
Oct 22, 2002 03:35 PM
