HELP!!!! car wont start
Old Apr 4, 2004 | 10:23 PM
4cefedcrx's Avatar
Default HELP!!!! car wont start
Went to start my car today and all it would do is turn over but not fire. A few days ago the tachometer started jumping from 0-8k when vtec engaged. Does anyone think it is the coil? Any help is greatly appreciated.
Old Apr 5, 2004 | 02:33 AM
jc836's Avatar
Default Re: HELP!!!! car wont start (btlefedlude)
I would suspect the control module in the distributor before the coil. This is assuming that you are stock. Also make sure that the cap and rotor are good. They do wear. If there is a lot of reddish dust in the distributor-better think about replacing it as that can be a sign of bearing failure.
Old Apr 5, 2004 | 05:46 AM
Sephro's Avatar
Default Re: HELP!!!! car wont start (jc836)
yeah I would bet it is your igniter. Pull the distributor apart. replace the igniter.
Your tach is run out of the distributor so that's why I would say that I am 99.99% sure that's your problem.
Old Apr 5, 2004 | 06:48 PM
4cefedcrx's Avatar
Default Re: HELP!!!! car wont start (Sephro)
well guys i got it fixed. I replaced the coil and it started with no problem. but thanks anyways.
Old Apr 7, 2004 | 07:15 AM
4cefedcrx's Avatar
well come to find out it wasnt my coil. went out yesterday morning to leave and the car wouldnt start again. noticed a wire had disconnected itself from the distributor. so i am on the way to take the coil i bought back.
BlitzSix
Dec 9, 2006 11:49 PM
sikluder
May 4, 2006 04:26 AM
eknine
Jul 28, 2003 08:02 PM
chirp2hrd
Sep 1, 2002 03:26 PM
gsrvx
Jun 6, 2002 11:27 AM
