Weird battery drain. heater panel lights stay on...why?
Old Apr 4, 2004 | 10:04 PM
Bailhatch's Avatar
Default Weird battery drain. heater panel lights stay on...why?
Car has been fine until today, charges at 14.3v, all other electronics work fine. I stalled it by dumping the clutch by accident. 2 hrs later battery is so dead it only cranks 1 revolution. Jumped it, started right up but lights on the heater control panel stay on even afer the key it out and off. Any ideas?
Old Apr 5, 2004 | 02:18 AM
gumbii's Avatar
hmm... you should check if you're ignition switch is working... you probably have some kind of short somewhere...
did you do a voltage drop test...?? you have alot of ingnition off draw if it drained you're battery that quick....
HezaDelsol
12
Aug 19, 2012 08:38 PM
vinai
Jan 6, 2009 10:57 PM
The HT
Oct 23, 2008 10:43 PM
lacking vtec
Jul 3, 2006 01:54 PM
goodOLdayz
Oct 12, 2005 11:06 PM
