VAFC problem - wtf a code?? - have had for 6months+
Old Apr 4, 2004 | 09:26 PM
Chemicalviper's Avatar
Default VAFC problem - wtf a code?? - have had for 6months+
1st off sorry for the long post!! but ive searched and asked all over.. never seen this problem. and i know i can rely on others when i need help on here.
Sup guys - I know how to work the vafc, what all the settings, mean, how its hooked up, and I have haqd absolutely no problems at all with it for the past 6 motnhs and is a good value in my mind for the fuel settings.
Well heres the deal....
it started throwin code 22 just last week, which is vtec malfunction, an awesome code to have
Heres what its doing ... only occasional, not constantly it will hit an artificial revlimter (wtf>?) at around 6500/6700, always same spot no matter how occasional. I was like wtf, took the code - it was 22, i was like ok ****, so i took off the solenoid, cleaned teh **** outta it, and the metal gasket, even as far as cleaning out the pressure switch.
All good for a day.
Does same thing .... took it into Acura, because i have warranty... so i was like whatever we will try it. They told me the vafc plays with the electrical too much and messes it up, and they have seen this twice on cars coming in, so they didnt do anything.
I was like fine, i reset the ecu, went on my way. I was tuning it again on the highway trying to get a nice pull for a 5th gear pull, so i was messin around with the points at which the fuel was adjusting, and adjusting the fuel itself....
code again godamnit, hit revlimeter at 6500ish, wtf. I now noticed this has happened to throw a code, every single time I was engaging vtec in 4th or 5th gear. So i shutoff car ... started it up... code still there... hits vtec all the way through just fine...
Someone tell me wtf is goin on, i asked all my buddies, who for the most have a Vafc - but no clue.
help?
Old Apr 4, 2004 | 11:22 PM
gamakichi77's Avatar
how high is your percentage of fuel enrichments?....is your's 12% and more? is you sets it at 12% or higher, it will throw codes...i'm facing this kind of problems lately....try not to sets it at 12% or higher...
hope this will help you...
i'm also still new with this VAFC.......correct me if i'm wrong.
Old Apr 5, 2004 | 01:20 AM
pbizzlegsr's Avatar
Default Re: VAFC problem - wtf a code?? - have had for 6months+ (Chemicalviper)
since the cel came one prior to your vafc installation..for sure it has to be the wiring..redo it..trust me its the wiring..if not its because you did not connect the blue wire which is the vtm wire.
Old Apr 5, 2004 | 08:04 AM
WCI's Avatar
WCI
Default Re: VAFC problem - wtf a code?? - have had for 6months+ (pbizzlegsr)
did you hook up the vtec oil pressure wire? I didn't hook it up once and it would feel like it hit a rev, limit. My cluster wasn't hooked up at the time so I dont know what code it was throwing though. Good luck
Old Apr 5, 2004 | 08:18 AM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbizzlegsr &raquo;</TD></TR><TR><TD CLASS="quote">since the cel came one prior to your vafc installation..for sure it has to be the wiring..redo it..trust me its the wiring..if not its because you did not connect the blue wire which is the vtm wire.</TD></TR></TABLE>
Wow, did you even read the post? He had it for six (6) months running before it threw a CEL.
Anyway, when you installed it, did you connect the VTM wire? I was having a similar problem because my dumb *** didn't hook it up, and once I did it was fine.
Old Apr 5, 2004 | 08:25 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: VAFC problem - wtf a code?? - have had for 6months+ (92b16vx)
i had this problem.
check your solderings. my VTEC splice became loose, and when jiggled would loose contact. so i would occasionally get a code 22 whenever i shifted because it would jerk the car enough to disconnect the wire.
my car ran fine for a year before this happened, so make sure all your connections are tight.
Old Apr 5, 2004 | 12:39 PM
Default Re: VAFC problem - wtf a code?? - have had for 6months+ (dLo GSR)
thanks guys ill check the wiring once i get home on thursday
edit -
I gave a guy who has done wiring for them numerous times, there is no VTM signal cuz its a 96 GSR, will scan in the VAFC handbook later, its h6-a - i do remember seeing a blue wire always hanging next to the ecu with electrical tape on it.
Old Apr 5, 2004 | 08:28 PM
pbizzlegsr's Avatar
go to apexi's site..theres an update which says even though your car may say it doesnt have vtm signal..hooking that wire up will get rid of all codes..
Old Apr 5, 2004 | 10:00 PM
92b16vx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pbizzlegsr &raquo;</TD></TR><TR><TD CLASS="quote">go to apexi's site..theres an update which says even though your car may say it doesnt have vtm signal..hooking that wire up will get rid of all codes..</TD></TR></TABLE>
schuetts
May 9, 2006 10:55 PM
cjames235
May 10, 2005 12:52 PM
CarAudiophile
Apr 22, 2004 04:10 PM
pbizzlegsr
Mar 8, 2004 04:33 PM
