clutch spings?
Old Apr 4, 2004 | 06:39 PM
TylerB's Avatar
Default clutch spings?
ok i was driving home, went to shift from 4th to 5th, clutch was extremely stiff on the pedal side.Wouldnt come out of 4th. So i stopped on the side of the road, wouldnt go in any gear. finally got it in 2nd, and drove home. Went for a test drive, it was ok at slow speeds but again wouldnt come out of 2nd. What do you think this could be?
Old Apr 4, 2004 | 06:43 PM
AndyD's Avatar
Default Re: clutch spings? (H22 VTEC)
Hey man, does the gear get COMPLETELY stuck in gear even when you push in the clutch?? Also, would you car drive like an auto tranny car when you came to a complete stop with the clutch pedal pushed all the way in??
Old Apr 4, 2004 | 06:54 PM
99spanishGT
Guest
Posts: n/a
Default Re: clutch spings? (AndyD)
im gonna say master or slve cylinder.
Old Apr 4, 2004 | 08:38 PM
Run Free's Avatar
Default Re: clutch spings? (spanishlude)
I kind of have the same problem too when I drive in a hot weather or for a period of time, my clutch gets stiff and my needle just bounces and sometimes my car won't even go. Had the clutch and flywheel replaced a month ago. What could be the problem be? Could it be the master cylinder? Need help too.
Old Apr 5, 2004 | 05:11 AM
TylerB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Hey man, does the gear get COMPLETELY stuck in gear even when you push in the clutch?? Also, would you car drive like an auto tranny car when you came to a complete stop with the clutch pedal pushed all the way in??</TD></TR></TABLE>
yes, it is completly stuck in gear, if you try to push it out it grinds and wont let you out. No, it would die if the clutch wasnt in.
Old Apr 5, 2004 | 05:23 AM
AndyD's Avatar
I had a very similar issue. It turned out to be a warped/bad clutch disk or a spring from the clutch disk popped out.
However, i did not have a VERY stiff clutch. To me, it doesn't sound like a bad clutch master or slave cylinder. It sounds more like a pressure plate issue.
Either way, I think it is time for a new clutch.
Good luck, man
Old Apr 5, 2004 | 11:53 AM
TylerB's Avatar
i talked with a guy about fixing it, and he says there are 2 clutch cables and that one might be miss aligned, is there any truth to this?
Old Apr 5, 2004 | 12:00 PM
Sephro's Avatar
that shouldn't change the feel of the clutch at all... Have someone step on the clutch pedal and see if the slave moves.... I have heard of the same problems with a popped spring. Did you hear any noise? Does it go into gear smoothly while the car is off??
Old Apr 5, 2004 | 12:01 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22 VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i talked with a guy about fixing it, and he says there are 2 clutch cables and that one might be miss aligned, is there any truth to this?</TD></TR></TABLE>
The cables have nothing to do with the clutch pedal. The clutch is hydraulic.
The cables only deal with the actual changing of gears.
Old Apr 5, 2004 | 05:42 PM
TylerB's Avatar
Default Re: clutch spings? (Sephro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephro &raquo;</TD></TR><TR><TD CLASS="quote">Did you hear any noise? Does it go into gear smoothly while the car is off?? </TD></TR></TABLE>
yes there are noises, sounds like washers are being thrown around sometimes when you move the shifter, And yes again, the clutch will engage will its not moving, or stopped. like, i can pull out but after 2nd (and sometimes not even that far) it doesnt do anything..
codybb4
Dec 9, 2008 08:44 AM
BB409
Jan 4, 2007 06:21 PM
candy eg
Jan 11, 2006 08:22 AM
herbalist
Mar 25, 2005 07:59 PM
Nick248
May 29, 2002 07:28 AM
