Sparks flying from starter wire..
Old Apr 4, 2004 | 04:02 PM
CrXstEalin's Avatar
Default Sparks flying from starter wire..
I did a b18a1 swap into my 88 crx si. car will not start. cranks but will not start..it has spark to all four cylinders and it is also getting fuel..Now since my battery is in my trunk i have a cable running from the positve termonal to the fuse box in the engine bay. now when ever i put this cable to the termanal it makes a **** load of sparks come someone help me please!
Old Apr 4, 2004 | 05:20 PM
CrXstEalin's Avatar
Default Re: Sparks flying from starter wire.. (CrXstEalin)
the sparks are coming from the termanal it self.
Old Apr 4, 2004 | 05:41 PM
igor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrXstEalin &raquo;</TD></TR><TR><TD CLASS="quote">I did a b18a1 swap into my 88 crx si. car will not start. cranks but will not start..it has spark to all four cylinders and it is also getting fuel..Now since my battery is in my trunk i have a cable running from the positve termonal to the fuse box in the engine bay. now when ever i put this cable to the termanal it makes a **** load of sparks come someone help me please! </TD></TR></TABLE>
It sounds like you have a short in the new cable. Go along it and see if you can see where the insulation has been worn through or chafed away.
Old Apr 4, 2004 | 06:34 PM
fullracegsr's Avatar
Default Re: Sparks flying from starter wire.. (igor)
you also should have another power wire coming from the positive cable for the starter... one goes in the box the other hooks to the starter...
Old Apr 4, 2004 | 06:54 PM
CrXstEalin's Avatar
Default Re: Sparks flying from starter wire.. (fullracegsr)
ya i do have a power wire from the termanal to the starter.but could the short in the other line cause the car not to start?
Old Apr 4, 2004 | 07:41 PM
Lscivichatch92's Avatar
mine did that and it turned out that i put the starter cable on upside down. but sounds to me like u gotta grounding issue
Old Apr 4, 2004 | 07:45 PM
CrXstEalin's Avatar
Default Re: Sparks flying from starter wire.. (Lscivichatch92)
What gauge wire should i use for the connection from the battery to the fuse box?
nexgen91
26
Nov 14, 2014 09:28 PM
CrxGrin
Dec 20, 2012 04:28 PM
logeywartooth
Feb 4, 2009 06:23 PM
gumbybum
Feb 8, 2003 11:25 PM
VTi NA
Nov 14, 2001 04:54 PM
