suspension question
Old Apr 4, 2004 | 10:57 AM
crxgator's Avatar
Default suspension question
ok as seen in the pics one of my shocks i just realized has only one nut and it doesnt look to be too great since it seems the shock is getting lower.
now does it matter if i just get two nuts from the hardware store and put them on? anyone know what size the nuts are(thread pitch)...also for me to swap out that one nut for the other two, can i just take it off how it is, or will that mess up the suspension and cause the entire shock to go down where i have to get a spring compressor and do it all over again?
Old Apr 4, 2004 | 12:09 PM
turbo96wr's Avatar
Default Re: suspension question (crxgator)
just take one of the other nut's with you and bye the correct ones then comeback and take the 1 that needs replacing and exchange nothing will happen also the big washer is upsidedown the edge with the ring goes up.
Old Apr 4, 2004 | 12:34 PM
crxgator's Avatar
Default Re: suspension question (turbo96wr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo96wr &raquo;</TD></TR><TR><TD CLASS="quote">just take one of the other nut's with you and bye the correct ones then comeback and take the 1 that needs replacing and exchange nothing will happen also the big washer is upsidedown the edge with the ring goes up.</TD></TR></TABLE>
alright thanks...i didnt put them together...thats how i bought it...
Old Apr 4, 2004 | 01:23 PM
Bailhatch's Avatar
one is a nylock and the other is double nutted. Both ways are viable in that application. The only reason to 'fix' it would be for appearance. DO fix the washers and maybe check the rest of the install for other assembly problems.
Old Apr 4, 2004 | 08:23 PM
dfoxengr's Avatar
yeah the washer lip is supposed to be facing up. you could think of it as a bowl..
Old Apr 5, 2004 | 09:15 AM
crxgator's Avatar
Default Re: suspension question (hybridvteceg)
to take off the nuts, do i use a 14mm wrench to turn the nuts and a 8mm(guessing) wrench to hold the shock from turning? or is there an easier way?
Old Apr 5, 2004 | 09:56 AM
dfoxengr's Avatar
impact wrench is easiest.
Old Apr 5, 2004 | 10:09 AM
dip-set's Avatar
lloks like those agx's need new dials also...www.kyb-tech.com tell them yours are beat up and worn and they will send u out a new set for each shock..they did for me...
Old Apr 5, 2004 | 10:11 AM
crxgator's Avatar
Default Re: suspension question (b18b-se)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b-se &raquo;</TD></TR><TR><TD CLASS="quote">lloks like those agx's need new dials also...www.kyb-tech.com tell them yours are beat up and worn and they will send u out a new set for each shock..they did for me... </TD></TR></TABLE>
sweet thanks for the link/tip...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">impact wrench is easiest.</TD></TR></TABLE>
what if i dont have access to an airgun...my tool supply is very limited...i have to be like mcgyver and use a peanut butter jar and aluminum foil to rebuild an engine...
Old Apr 5, 2004 | 11:25 AM
dfoxengr's Avatar
i guess an allen wrenh and an open end are your only choices then. i would invest in a lot of tools if i were you, ive probably spent way too much on all mine but i normally dont have to ghetto-tool things anymore.
Old Apr 5, 2004 | 11:54 AM
crxgator's Avatar
i cant use an allen wrench on these...
Old Apr 5, 2004 | 12:14 PM
dfoxengr's Avatar
then get better tools, harbor freight had an electric impact for like 60 bux.
Old Apr 6, 2004 | 09:35 AM
dip-set's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">ok as seen in the pics one of my shocks i just realized has only one nut and it doesnt look to be too great since it seems the shock is getting lower.
now does it matter if i just get two nuts from the hardware store and put them on? anyone know what size the nuts are(thread pitch)...also for me to swap out that one nut for the other two, can i just take it off how it is, or will that mess up the suspension and cause the entire shock to go down where i have to get a spring compressor and do it all over again?</TD></TR></TABLE>
see the rubber bushing there in the pic..what would cause them to kinda shred along the edges,i had new ones put in with my spring install last week and now i see lil rubber shreddings around that area in the pic...thanks
accord478
Jul 3, 2007 04:03 PM
MR_Ek4
Suspension & Brakes
Sep 8, 2006 03:34 PM
TurboTeG4
Apr 24, 2004 06:23 PM
