Timing Question.. (I searched)
Old Apr 4, 2004 | 09:40 AM
user 996328629's Avatar
Default Timing Question.. (I searched)
I have a 2 layer headgasket on my recent build, but when i went to line up my cam gears they are a hair off. Im assuming this is because of the lack of 3rd layer in the gasket.
how do i set the cam gears to compensate for this?
My car is lacking alot of power, and im not sure if this is it, or because i need tuning despertly.
Old Apr 4, 2004 | 03:49 PM
Default Re: Timing Question.. (Swags04)
ttt
Old Apr 4, 2004 | 03:53 PM
SleepyHF's Avatar
what is the block timed at??
Old Apr 4, 2004 | 05:24 PM
Default Re: Timing Question.. (SleepyHF)
20 degrees is the timing now
Old Apr 4, 2004 | 05:30 PM
SleepyHF's Avatar
set the block to 16 degrees before TDC, then set the cam. If that dont work, pull the cam gear off, turn it over and check the key to see if it has moved at all. This happend to me once!!
Old Apr 4, 2004 | 08:04 PM
huh?
Igaly
Honda Civic (2001 - 2005)
11
Feb 15, 2009 06:40 AM
ef-hatchcrap
Jan 25, 2008 12:45 PM
97grnrs
May 10, 2007 03:25 PM
boonacka
Sep 1, 2006 10:43 AM
itr1236
Dec 9, 2001 05:09 PM
