Troubleshoot: Slipping out of gear and grinding
okay i'm having to have a problem where i drive the car in a gear and it slips out of the gear like if i accelerate to to much it will slip... what is the problem is it the syncros? because everytime i vtec it and shift from 2nd to 3rd it always grinds first and then goes in gear, i really want to know what the problem is so i can get it fixed asap, thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUMPTHELIGHT »</TD></TR><TR><TD CLASS="quote">HOW MANY MILES YOU MAY NEED A CLUTCH BUT IF YOU TRANS IS GRINDING THEN YOU OBVIOUSLY NEED TO DO SOMETHING ABOUT IT. MAYBE SYN.</TD></TR></TABLE>
gotta love jersey edumacation
who cares about the mileage?
if hes able to get it into gear, and then it pops out of gear under heavy load i'd say his syncro teeth are non existant...
i'd highly doubt its the clutch nor pressure plate otherwise he'd have massive problem getting it into gear in any gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boges »</TD></TR><TR><TD CLASS="quote">The first step would be to check the tranny fluid. </TD></TR></TABLE>
I recently swapped trans, and it turns out that one of the bolts on the tranny case was not all the way tight, so it slowly leaked out fluid. The symptoms were the exact same as yours until I tightened the bolt and topped it off.
i'am completely clueless of where to start at, and where is the first place i look? i have a exedy stage 3 clutch put in about 5 months ago
Like people have said, check the tranny fluid for quantity and condition. If you don't know how, take it to a shop and have them do it.
It is poping right out of gear, putting itself in neutral, right? Or is it just the clutch slipping while it is in gear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dels98R »</TD></TR><TR><TD CLASS="quote">It is slipping while it is in gear</TD></TR></TABLE>
Your clutch is dead. Slipping while in gear is not a tranny problem.
