97 mini me oxygen sensor help
Old Apr 3, 2004 | 09:59 PM
97mini-me's Avatar
Default 97 mini me oxygen sensor help
I have emissions coming up and I need to get my secondary o2 hooked up. I can only find three wires coming from the computer for the secondary o2. I am missing a ground. I looked at all the wiring schematics in the honda book but some parts don't make any sense. This is the only part left to do. I have tried a ton of grounds and none of them work. The CEL is off when I turn the key to position II but when I start it, after about 30 seconds it comes on. Can anyone give me a diagram on how to hook this up?? Any help is greatly appreciated!!!!!
Old Apr 3, 2004 | 10:01 PM
97mini-me's Avatar
Default Re: 97 mini me oxygen sensor help (97mini-me)
By the way, it's a 96 ex ecu (obd2a) in a 97 dx hatch.
Old Apr 4, 2004 | 07:17 AM
97mini-me's Avatar
bump....I NEED HELP!!!
Old Apr 5, 2004 | 01:16 PM
civic-4-ges's Avatar
Final remaining wire connects to your purge valve. Take a look at it, its black and yellow. If you run a continuity test on that and the same wire on your primary o2 sensor, you will find they are the same circuit
walrus_07
Jul 1, 2012 01:54 PM
Speed_1
Feb 7, 2007 04:59 PM
Azntwins
Jul 8, 2004 10:31 PM
worrdogg
Oct 4, 2003 10:03 AM
clean
Aug 13, 2001 10:06 AM
